3D printed parts - Defender Source
Old August 15th, 2013, 07:38 AM
3D printed parts
Someone suggested that I have some custom parts done up on a 3D (metal) printer. Yes, sounds good sez I.
I question how good a printed part would be over say a cast iron or sintered metal part? Would it be as strong under load
Old August 15th, 2013, 08:42 AM
BlackField's Avatar
BlackField
Oscar
D110
3D parts are not usually printed in metal. While possible I think having a machine shop make your parts in "3D" would be more common and cheaper. 3D parts are usually some form of plastic.
As far as strength I suppose it has the possibility to be stronger by making alternate layers aligned differently like plywood? Sounds like it could be awesome. I just haven't seen much of it while reading about regular 3D printers.
Old August 15th, 2013, 09:24 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
From experience I have never seen a 3d printer that uses metal. What I have seen and have access to is a 5 axis vertical mill that takes solid blocks of aluminum/mild steel and machines the block down. Usually using a CAD software. What are you trying to have made? The most time consuming part and most expensive is putting it into the software, depending how complicated it is my shop charges $30-60 an hour plus material and machine time.
Old August 15th, 2013, 09:31 AM
There are plenty of places on the web that will print stuff in metal. It uses stainless powder that is held together with glue. The printed object is cast in sand, heated and infused with bronze.
The surface is rough so it would need clean up.
Old August 15th, 2013, 09:40 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
Cool I never realized that, now the question is strength? What do you need made? How important is the structural integrity?
Old August 15th, 2013, 10:05 AM
I have heard of ones that use aluminum wire too.
Old August 15th, 2013, 11:49 AM
Ragland's Avatar
Ragland
Robert Ragland
1994 Defender 90
I'm hoping printed parts will be a possible solution to NLA or obscenely expensive small batch re-issued parts, particulary interior trim pieces.
"Uhh...I think they all leak like that."
Old August 15th, 2013, 01:19 PM
Yawp that's what Leno does.
part, parts
FS: NAS 93-97 Printed Parts Catalogue RTC9962FN kiphartzell For Sale - Parts 10 January 26th, 2016 07:44 PM
D-90 1994 parts and Disco 2 parts JAD For Sale - Parts 10 August 1st, 2006 03:00 PM
FS: OldMan EMU & RoverTym parts RoverWrecks For Sale - Parts 14 June 12th, 2005 10:05 AM
Help empty my garage! Ton's of parts.. RedRhinoProducts For Sale - Parts 12 June 1st, 2005 09:24 AM
spring cleaning- D90 parts Chris Cox For Sale - Parts 13 April 4th, 2005 01:51 AM
