36 spline versus 48 spline steering wheels - Defender Source
Old August 16th, 2013, 10:32 AM
transientmechanic's Avatar
transientmechanic
1972 SIII
I have spent some time researching this but cannot find the answer I am looking for.
I have a Defender column from an unknown year truck. My Series 3 steering wheel does not fit. The female spline on the wheel is too large.
This is the simple question I need answered,
I see the 48 spline column referred to as the "fat" shaft. But, are the actual splines a smaller diameter than the 36 spline? And the column fattens up after the splines?
Also, is there any difference at the steering shaft end between the two columns?
I need to buy a steering wheel and I dont want to do this twice...
Old August 16th, 2013, 10:49 AM
I'm not sure I understand the problem. there are two shaft splines, 36 and 48. 36 is smaller than 48..... You need a 36 spline wheel (or boss) for a 36 spline shaft. LR went back and forth from the two splines a few times.
Old August 16th, 2013, 10:56 AM
transientmechanic
1972 SIII
Right but as far as I understand, my Series 3 wheel should be 36. If that is true, then I must have a 48 spline column which is actually a smaller diameter spline despite the higher spline count.
Old August 16th, 2013, 11:35 AM
No, Series wheels are 48 spline. You can count them....
Old August 16th, 2013, 11:41 AM
transientmechanic
1972 SIII
Of course I could count them except my shop is an hours drive away and I only have time to get there once per week.
Are you sure all Series wheels are 48? I thought early II/IIA are 48 and then Series III (like mine) is 36.
Old August 16th, 2013, 12:18 PM
Everything I read is the later series trucks are 48 spline and match the 300TDI era Defenders.
transientmechanic
1972 SIII
That web rover link is good but I'd rather see photos of the column ends next to each other actually showing the splines instead of just ambiguous wheel photos. The large versus small smaft nomenclature is confusing if the spline diameters are actually opposite of that.
Old August 16th, 2013, 12:20 PM
Series wheels are 3/4-48, except for early banjo. Later Defender wheels are 3/4-36 or 1-48 spline. These are pretty much standard sizes.
The shafting components and power steering inputs are all 3/4-48 for all years and models (that may have changed with the latest batch of LR3/4, RR, Evoque, etc. which are probably metric, but I don't know)
Old August 16th, 2013, 12:29 PM
I'm pretty sure the 48 spline Defender wheels are 3/4", same as later Series. The 36 spline is non standard.
https://www.merlinmotorsport.co.uk/s...its/land-rover
Old August 16th, 2013, 12:34 PM
transientmechanic
1972 SIII
Glad im not the only one confused here...!
Old August 16th, 2013, 12:41 PM
transientmechanic
1972 SIII
Yes. But the Defender column I have does not fit the series 3 spoke.
Old August 16th, 2013, 12:45 PM
transientmechanic
1972 SIII
I'm not sure. This transpired just as I was leaving the shop yesterday and I figured I could find an answer quickly on the web (should have known better). I did not count the splines but I can tell you the spline diameter of the column is significantly smaller than the spline in the 3 spoke series wheel.
Old October 11th, 2013, 10:54 AM
transientmechanic
1972 SIII
Yes I was able to make the hour plus trek to the shop finally. Fabricated a steering box bracket and counted the splines on the column - 36.
The 3-spoke Series wheel must be 48 (I didnt count that because it doesnt really matter).
So I am now on the hunt for an old-school 4 spoke 36 spline wheel.
Old October 14th, 2013, 07:28 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
The three spoke SIII wheel fits the NAS spec column. Unless someone is slipping me weird columns.
------ Follow up post added October 14th, 2013 07:32 AM ------
....or P38? DII? pretty sure they are different unless I am missing something in my mix and match world.
Matt Browne
Old October 15th, 2013, 11:16 AM
hoxie173's Avatar
hoxie173
Matt Hawkes
1959 S2
I just went through this on the hybrid I'm building. I had a defender column from a unknown truck. The lower spline was the standard 3/4"-48 but the upper measured 11/16"-36. I used a old school 3 bolt hub from a junkyard chevy to mount a flat wheel.
ID:	82115   Click image for larger version
Old October 15th, 2013, 11:31 AM
Matt,
What thread pitch/diameter is the nut that threads onto your steering wheel shaft?
Old October 15th, 2013, 11:56 AM
hoxie173's Avatar
hoxie173
Matt Hawkes
1959 S2
Matt,
I just measured it and it looks like 9/16"-18
Old October 15th, 2013, 06:30 PM
Thanks!
Old October 16th, 2013, 05:49 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
Great. Now I dont know what the heck I did as I honestly was pretty excited when the Series III wheels dropped right on the last two Defender columns I used. Thought they where NAS columns.
Matt Browne
Old October 16th, 2013, 02:08 PM
transientmechanic
1972 SIII
Matt, when I did the PS conversion on my IIA ten years ago I was able to drop a 3 spoke SIII wheel right on using an unknown Defender column as well. Thats why I was surprised when it didnt this time around. This time, I have the same column that the other Matt does.
Be careful. Friends don't let friends drive with vice grips on the steering shaft nub.
wheel, wheels
48 Spline Steering Wheels Brand New DefenderPilot For Sale - Parts 0 June 1st, 2012 01:33 PM
Steering wheel 48 spline with hub Rugbier For Sale - Parts 9 December 12th, 2011 08:21 PM
Steering wheel 48 spline Rugbier For Sale - Parts 7 November 23rd, 2011 03:50 PM
Used type "B" Steering Wheel - 48 Spline 16kpsi For Sale - Parts 0 January 26th, 2011 04:45 PM
48 Spline Leather Steering Wheel CDeWan For Sale - Parts 32 January 22nd, 2011 03:17 AM
