36 -> 48 spline adapter - Defender Source
Old December 17th, 2015, 06:59 PM
PabloCocito's Avatar
PabloCocito
Pablo Cocito
1987 Defender Tithonus
Does anyone make an adapter to fit a 48spline wheel on a 36spline defender? I started to make one from an old wheel but I realized that it might be too weak.. The walls of the adapter would be about 1-1.5mm thick...
I machined the hub from the old wheel to keep the internal splines, now I just have to turn it down to 3/4" and cut the 48 splines to fit the new wheel.
Would this be too weak? it would be a spacer to make up for the size difference pretty much, but with spines on Both sides.
Progress pic
Splines are actually in good shape, I just didn't clear the burs after chamfering
ID:	137352   Click image for larger version
Old December 17th, 2015, 10:04 PM
DannyboyUpstate's Avatar
DannyboyUpstate
Danny Harrington
1983 110 3-door
I would really like to find a smaller diameter steering wheel for my truck that is still OEM. Hard to do on the early 110s.
Old December 17th, 2015, 10:34 PM
Actually later wheels are the same spline as the early ones. http://www.web-rover.co.uk/nav.php?p...steeringwheels
Old December 17th, 2015, 11:37 PM
Progress pic
Most just change the steering column for the other spline. Way faster than making something which will put the steering wheel closer to you and further cramp things.
Old December 17th, 2015, 11:43 PM
DannyboyUpstate
Danny Harrington
1983 110 3-door
Originally Posted by Red90 View Post
Actually later wheels are the same spline as the early ones. Web Rover
Did not know that! Do you know if that style wheel's overall diameter is different then te earlier style 4-spoke wheel?
WTB: 4.7 24-spline (4-pin) complete rear diff 3rd member (24-spline axles too) modrover Wanted 1 November 18th, 2015 09:40 AM
WTB: 4.7 Rover 24-spline diff with locker & 24-spline axles modrover Wanted 4 September 27th, 2015 07:24 PM
Rear Axle: 10 Spline to 24 Spline Conversion / Seal Refresh / Ashcroft Locker Install sonoronos Smaller Projects 44 February 27th, 2015 05:20 PM
Boss 48 spline hub adapter Momo Ben01 Wanted 5 March 26th, 2014 03:40 PM
36 spline versus 48 spline steering wheels transientmechanic Defender Technical Discussions 31 November 13th, 2013 09:57 PM
