35 x 12.5" tires on D110 wheels - de-beading - Defender Source
Old July 14th, 2009, 09:37 PM
cdb
Clark Bowen
I'm currently running stock 7" wide RRC alloys with 35x12.50 Nitto Grapplers and want to switch to steel D110 wheels. However, they are only 6.5" wide and I'm worried about de-beading.
Does anyone run D110 steel wheels with tires this wide at Moab, Rubicon, etc aired down to 10-12 lbs without debeading?
Old July 14th, 2009, 09:39 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
RRC alloys hold the bead MUCH better than steel wheels anyway. I think 6.5" wheels are too thin for a 12.5" tire.
Old July 14th, 2009, 09:51 PM
cdb
Clark Bowen
Why do they hold a bead better?
I figure it would be in the construction as I don't see how the different metals would effect de-beading.
Old July 14th, 2009, 10:29 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Factory 93 110 rims don't have a safety bead on the rim designed to help hold the bead to the rim, normally these type rims are for tubed tires, not a good idea for tyres you'll air down.. Keep the alloys or do a GCR steely that's a bit wider for a 12.5 tire.. IMO 7" is the minimum and that's not recommended by most MFGrs'
Keith
Big, Red and ... aaa Red..
Old July 14th, 2009, 10:57 PM
cdb
Clark Bowen
Keith.........
I'm surprised that the steelies don't have the inner bead lock as I've aired down to 8 lbs with the D110 wheels on my D90 with 285/75/16 mud terrains and had no problems before.
Thanks for the info - guess it kills that swap idea. Back to mulling and brooding.
Old July 15th, 2009, 12:09 AM
First, there are tubeless versions of the 6.5" rim.
Second, if you have ever tried to break a beak on one of these tubed rims, you will realise that the lack of a safety bead does not matter. IME, after just manually changing around 30 tires, the tubed Rover steel wheels hold the bead on a lot better than any normal "safety bead" tubeless rims I've seen.
Third, I've run tubeless on these rims for the last 7 years and only dropped a bead once. I always run low pressures.
A narrow rim holds a bead better than a wider one off road. They are more squirmy, but it is harder to knock off he bead.
However, with all that said, I think the backspacing on the factory 6.5" rims is too large for a 35x12.5 and you will have clearance issues unless you use spacers.
Old July 15th, 2009, 01:35 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Regardless of what kind of bead the wheels have, different tires and different wheels react to eachother differently. There are no guarantees that any combination will hold a bead well or not.
That said, 10-12lb is a lot. I would be surprised if there is an issue on a 6.5in rim.
Now for the kicker, it doesn't matter. A 6.5 is way too skinny for a tire that wide. It will look bad, act bad, and wear bad.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old July 15th, 2009, 08:48 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
I run 35x12.5 Swamper SSRs on the NAS 110 rim (ANR1534PM) with no issues at all (no tubes). They hold the bead great and I usually run them down at about 7 to 10 psi depending on ground conditions.
There are no driving or wear issues at all. With regular rotations I got almost 40K out of the last set of tires (that is good for SSRs).
That rim has the best offset of all the Rover rims, for turning radius, that is the reason I went with it in the first place. Had them all over Moab and New England.
They actually hold the bead better than the 36" SXs I have on MRT 15" beadlocks. The beadlock part holds as it should, but the rim is so wide that it will drop the inside bead periodically when really air'd down because the rim is so wide it does not put any pressure on the inside bead when on a side load.
I too like a rim that is "too narrow" (according to a tire manufacture) as it is the way I get a cheap beadlock.
Works 100% for me, your results may vary.
Speaking of that, if anyone wants a set of MRT 15" beadlocks let me know. I hate those rims.
Email:
Old July 15th, 2009, 12:17 PM
cdb
Clark Bowen
Mike....
Do you use spacers?
Old July 15th, 2009, 12:25 PM
ECR's Avatar
ECR
I should, to get a better turning circle, but I don't/ haven't.
No real reason there, other than I just got used to the turning radius and can live with it.
Email:
Old July 15th, 2009, 01:49 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Ahh, see I had problems with the tubed 110 rims loosing beads. 36/12.5-16 swamper SSR Radial.
That was at low 6-8psi pressures so I switched to a rim with a safety bead, no trouble since, if I go lower it will be with bead locks.
The tubed rims where also too narrow for my tastes, I went to an 8" rim.
Of course I had wheel spacers for the 6.5's and kept them on for the 8's, it's very stable on a side hill..
Around here some shops won't even mount a tubless tire on a tubed rim.
Keith
Old July 15th, 2009, 05:07 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Jorge runs 36" swampers on wolf rims with no problems also. Are the wolf wheels thinner then the 110 rims?
Legend in My Own Mind.
Old July 15th, 2009, 05:15 PM
nope. both 6.5"
Old July 16th, 2009, 12:42 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
6.5 on a 12.50 tire is too skinny. It will crown badly and "roll" when aired down. The only question is whether or not this will bother you. I noticed better performance when going from an 8in wheel to a 9in wheel. I have run a 31x19.50 on a 6in wheel and it sucked.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old July 16th, 2009, 09:04 AM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
93 110, 90 RockRR buggy
"I have run a 31x19.50" That must have looked sweet, were those Thornbirds?
Old July 16th, 2009, 09:41 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
ahhh, 10.50. Typing on an iPhone here, cut me some slack!
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
110, d110, tire, tires, wheel, wheels
Set Of 5 Black Steel Wheels And Tires jonathon For Sale - Parts 3 August 4th, 2005 01:45 PM
Tires and Wheels Jeremy Keith For Sale - Parts 6 July 12th, 2005 12:25 AM
tubless tires on tubed wheels asurover Defender Technical Discussions 2 February 3rd, 2005 01:30 PM
110 steel wheels and tires artm For Sale - Parts 3 January 21st, 2005 09:06 PM
Wheels & Tires roverboy For Sale - Parts 0 March 10th, 2004 03:13 PM
