35 x 12.5 on 15 x 7 - Defender Source
Old May 3rd, 2011, 01:15 PM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
35 x 12.5 on 15 x 7
anybody running this? or are most of you on a wider wheel? it seems like going with a 7" wheel would pull the tire in a little narrower. but I don't know if that size tire really needs a wider rim.
if anyone is running a 15x7 with a 35x12.5x15 tire could you please post up some pics?
thanks
That is why it is called a short cut. If it was easy it would just be "the way."
Old May 3rd, 2011, 02:10 PM
jetmech's Avatar
jetmech
Dave McHenry
1984 Landrover 90 CSW
i would not go smaller than an 8" rim. you will put stress on the side walls and the sealing bead.
Old May 3rd, 2011, 08:35 PM
cdb
Clark Bowen
This issue has been beaten to death, but I had absolutely no problems running stock D90 wheels (16X7) with these size tires. This is something Land Rover has done a great job with.
The problems developed when I went to 8" wide non-LR wheels and they de-beaded twice on one trail.
The D90 wheels have an excellent bead and this size tire is no problem at all.
There is a post from Mike at ECR running Super Swampers on the LR 6.5" steel wheels with no de-beading issues.
If you are running non-LR wheels, my guess is your beads won't be that great at 7".
2011 RR HSE -
2001 GMC 2500 4wd
Old May 4th, 2011, 02:52 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Probably better to say specifically alloy 16x7 wheels. With more an more non-NAS trucks coming to the US, "stock" is not going to mean much. Standard 90 wheels outside the US are 5.5x16 steel.
Agreed that LR alloys are better at retaining the bead than most steel wheels.
15x7 are going to be aftermarket, and my humble opinion is that 8 inch would be better for a 35x12.50 to reduce the risk of popping a bead when running low pressure.
Tony
1984 110 "Smokey" (sold)
Want 35x12.5 15 SSR NVail Wanted 5 January 26th, 2011 11:23 AM
por 15 in waxoly spray gun? Campbell Defender Technical Discussions 5 July 12th, 2010 09:42 PM
F/S 5 15 x 10 Allied Beadlocks pushngo For Sale - Parts 1 November 25th, 2009 10:00 AM
F/S 15 x 10 Steelies pushngo For Sale - Parts 0 October 12th, 2008 07:16 AM
35 x 12.5 x 15 Super Swampers Slick62 For Sale - Parts 0 March 24th, 2008 04:19 PM
