35" Tires - Defender Source
Old April 5th, 2004, 11:03 AM
Doug_Paoletti
Douglas P. Paoletti
'94 D90
35" Tires
I realize there is info on this topic in the FAQ section, but I cannot seem to decipher a definitive answer (maybe it is just me), so I thought I would ask: Can I squeeze in 35 x 12.5 x15's with 2 - 2.5 inches of lift (like the SafariGard Stage II) or do I need to go with 3 inches or more of lift (like the SafariGard Stage III) and deal with the associated suspension geometry problems/costs?
I do not want to cut my fenders, although I would have no problem cutting the plastic flares.
Any and all advice would be much appreciated.
Doug
Old April 5th, 2004, 11:40 AM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
Yes you can!
World traveler
Old April 5th, 2004, 12:02 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
no problem.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 5th, 2004, 12:04 PM
Doug_Paoletti
Douglas P. Paoletti
'94 D90
Yousef:
You mean "yes you can" as in, use 35's with 2 - 2.5 inches of lift and no fender cutting?
If that is correct, then how would you recommend achieving that lift? The SafariGard stage II seems awfully expensive compared to some of the other options. Any thoughts on whether or not it is worth the extra $$$?
Doug
Old April 5th, 2004, 12:19 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
You can fit 35's with 1.5" lift if you want.
If you don't want to spent the $$ on SG suspension, then go with OME 751/764 with RockWare rear shock mounts and some LT shocks. With this setup you should be able to fit the 35's and not worry about driveline geometry.
World traveler
Old April 5th, 2004, 12:45 PM
Doug_Paoletti
Douglas P. Paoletti
'94 D90
Thanks guys
Old April 5th, 2004, 03:58 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
Doug, I have the Stage II kit and I fitted Super Swamper SSR-TSL's 35x12.50x15's. The rims have 4" backspace.
I trimmed the plastic fender flares and had to trim a little off the rear fenders rear edge (aluminum) to clear at full stuff.
I really didn't want to trim metal but it is pretty simple and most Rover people don't even know unless I point it out.
I would give Steve at Rovertym a call about their lifts, he has been very helpful, they have great products, and they also have lift kits. www.rovertym.com
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. -Thomas Jefferson
Old April 5th, 2004, 04:03 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Or, you could fit 37's with 2.5 inches of lift
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 5th, 2004, 04:19 PM
nice.
Old April 5th, 2004, 04:38 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
and if the 2.5" is to much, here is a picture of my 90 with 2" and 37's
I think Troy ran his 37's on 1.5" lift
World traveler
Old April 5th, 2004, 04:55 PM
Wait a second with that logic I should be able to fit 40's with my 4" of lift.
Old April 5th, 2004, 05:01 PM
pangaea's Avatar
pangaea
Nathan Hindman
95 Discovery, D130
Douglas,
If you want a bit of extra lift over the standard 1.5" OME lift you can get some extra lift with any of the following configurations:
2.25"
OME 767 front (HD diesel spring)/764 or 762 rear with .5" spacer
3" lift
OME 764 front (MD rear application)/764 with 1.5" spacer or the 781 with .5-1" spacer
Nathan Hindman
http://www.pangaea-expeditions.com
Old April 5th, 2004, 05:16 PM
Doug_Paoletti
Douglas P. Paoletti
'94 D90
I just hung up with Steve at Rovertyme - he was most helpful and suggested that I go with his 2" springs (which he says will give me close to 2.75" of lift with the D90ST). I should have them in a couple of days...
Old April 5th, 2004, 05:37 PM
No trimming??????
I've seen 33" tires just hit so how can you guys say that 35x12.5 will clear?? Me confused. Properly designed spring lifts by themselves should not affect tire clearance. You should still have the same range of axle movement as that is limitted by the shocks.
I really can not see how you would not need to trim with that size of tire.
Old April 5th, 2004, 06:12 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
It depends on which wheels you use. I ran 35's on 15X7 with OME springs and did not have to trim anything. I ran my 37's with RTE 3" springs and 15X8 wheels and had to trim just a little bit of the aluminum, and with the 10" wheels, and same lift and tires had to trim more.
The only problem with running 35's is the rear tub where your tire will hit the tub from the inside but the front is fine.
World traveler
Old April 5th, 2004, 06:17 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Yousef's right. With 37's and 15x10's I had to cut a crapload off. But I can stuff the 37's as far as I could the stock 31's.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 5th, 2004, 06:19 PM
Doug_Paoletti
Douglas P. Paoletti
'94 D90
That is a perfect segue into my next question:
If I am going with the 35 x 12.5 tire size, am I better off with 16x7 inch rims or 15x8 inch rims?
Old April 5th, 2004, 06:23 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
15x8
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 5th, 2004, 11:35 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
16" rims are better on road where you'll find more selection in the 15's. If you go with the 16X7 the tire will not stick out as much as the 15X8, so it's your choice.
If you want to stay with 16" wheels try Trek outfitters as they have the 16X8 in steelies.
World traveler
Old April 5th, 2004, 11:45 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
Douglas, this just doesn't get any better
http://www.defendersource.com/forum/...&threadid=1636
And I think Dave Lucas has a set of 5 15X8 wheels in good condition, don't ask me how I know
World traveler
tire, tires
Tires: an odessy souza Misc. Chit-Chat 37 December 14th, 2009 05:57 AM
D90 Precut Fender Flares for 35" Tires taoseno Wanted 0 May 4th, 2009 01:18 PM
Tires, Tires, Tires Joe P Misc. Chit-Chat 28 August 9th, 2005 09:58 PM
4 BF Goodrich Mud Tires Jeremy Keith For Sale - Parts 5 March 3rd, 2005 07:09 PM
BFG AT Ko tires for sale Seriesman For Sale - Parts 6 August 18th, 2004 11:09 PM
