300tdi Zeus Gear Removal - Defender Source
Old November 16th, 2012, 09:53 AM
Epsom_D2
Sean-Paul Ferrera
1994 D90 POE
When I purchased my 300tdi it came with Zeus gears (yes I know the horror). Recently it has started to make a racket and before I find out the very expensive way, I would like to convert back to the timing belt. The problem is that I have no earthly idea what parts I may need to go back and I'm not seeing any fitting instructions anywhere for the Zeus gears.
If anyone has any idea of what parts I may need to go back to the timing set I would appreciate you posting them here. As I know it I need an oil plug for the block, updated timing belt set, and a timing cover.
Thanks.
S-P
300tdi, tdi
Crankshaft timing gear removal Jymmiejamz Defender Technical Discussions 5 January 29th, 2012 08:34 PM
Zeus gear conversion in 200 TDI kjva Defender Technical Discussions 4 May 21st, 2011 07:27 AM
Removing crank gear 300tdi D90user Defender Technical Discussions 6 November 2nd, 2010 12:09 AM
300tdi crankshaft gear D90user Defender Technical Discussions 0 October 19th, 2010 01:07 AM
Speedo Gear Removal 48vphantom Defender Technical Discussions 2 March 27th, 2005 02:51 AM
