300TDi won't start - Defender Source
Old February 18th, 2014, 09:23 PM
IvanKV's Avatar
IvanKV
Ivan
'89 110 County - 200TDi
300TDi won't start
Well I popped my LR Breakdown cherry, my 300TDi equipped D1 wont start.
Its not the battery and Autozone said its not the alternator.
Luckily my fraternity brothers were able help me push it and we roll started it.
Any thoughts?
Old February 18th, 2014, 09:25 PM
fuel shut off solenoid getting 12v ?
Old February 18th, 2014, 09:30 PM
IvanKV's Avatar
IvanKV
Ivan
No idea, how do I check
Looking for my manual now.
Old February 18th, 2014, 09:33 PM
Look for the one wire to the injection pump. Listen for it clicking when you turn on the ignition. Check for power at that lead.
Old February 18th, 2014, 09:45 PM
You roll/pop started it? Could we just be talking about a bad starter here? I'd think if it was the fuel solenoid that a pop-start wouldn't work regardless.
Old February 18th, 2014, 09:56 PM
IvanKV's Avatar
IvanKV
Ivan
Well shit, that's expensive... 499.99 from RN
Earlier today it wont start then we opened the bonnet and it started up.
Two hours later it wont start without the roll.
Old February 18th, 2014, 09:57 PM
Does it click or turn over when you try to start it? Or literally do you get nothing when it's the no-start situation?
I think I found some alternate Tdi starter sources that were in the $200-300 range, let me check...but don't start buying parts just yet!
Old February 18th, 2014, 09:58 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Check that all of the electrical connections are clean and tight. Sounds like a loose connection.
1970 SIIA 88, Sold
Old February 18th, 2014, 09:59 PM
IvanKV's Avatar
IvanKV
Ivan
Nothing at all, not a squeak. The dash lights dim light normal but no movement or sound.
Old February 18th, 2014, 10:00 PM
Agreed. I'd even start with something as simple as the connections on the battery and work out from there. Once I had my battery out in the 90 and just popped the terminals on by hand and forgot about it. Got a ways down the road before total electrical failure .
------ Follow up post added February 18th, 2014 10:03 PM ------
Hmmm...could also be a faulty ignition switch. My Tdi would do that from time-to-time, and finally determined it was the switch. In that situation for me it was intermittent, but when the switch went in the 90 it was a total failure with no warning. So hard to say for sure and a bad switch can give slightly different symptoms.
But you do have dash lights/etc correct? If that's the case, I'd put money on the starter or the ignition switch. But the pop-start I'd lean towards a starter, but the ignition switch is cheap enough (~$30 or so) it may make sense to start there. Even if you replace that and it's not it, just stick the old one in the cubby as a spare - trust me you'll need it at some point.
Old February 18th, 2014, 10:15 PM
X2. Go for the cheapest solution first which is confirming strong/secure connections. Starters are expensive, but shouldn't be $500. Look elsewhere once you confirm that indeed the starter (and not just the connection(s)) is the issue.
IvanKV's Avatar
IvanKV
Ivan
Yes, lights, radio, AC, seat heaters, windows all work.
Old February 18th, 2014, 10:54 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Starters are simple items internally. Do you feel comfortable disassembling it ?
You could also take it to a local auto electric shop and have them go through it. Mine is 12 years old & 150K miles. I had to take it apart & clean it up about 1-1/2 years ago. They get dust and grime inside & also the oil/grease on the solenoid gets sticky after a decade.
Old February 18th, 2014, 11:01 PM
IvanKV's Avatar
IvanKV
Ivan
I have no mechanically experience, putting on the engine cover the other day was my first foray[into the engine bay]. I am, however, willing to learn. Will take it out tomorrow
Old February 18th, 2014, 11:22 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Don't take out the starter until After you have confirmed that all of the connections and clean and tight.
1970 SIIA 88, Sold
Old February 19th, 2014, 12:14 AM
genie90's Avatar
genie90
Jay Geaney
1994 D-90 ST #282
Granted I don't have a tdi but it does sound like an ignition switch to me like Lav mentioned. Had the same problem with my NAS- easier and cheaper than replacing a starter only to later find it was the switch!
Cheers
Jay
Old February 19th, 2014, 07:15 AM
I had intermittent starter problems 2 years ago that plagued me for a month, and it ended up being a loose and dirty starter cable at the union under the turbo. brass brush and tightening the nut solved my issue. this would account for all dash gauges working, but only sometimes starting.
Mark Kellgren
KM4BOR
Old February 19th, 2014, 07:38 AM
I would check that the ground cable is properly secured to the chassis and transfer box.
Old February 19th, 2014, 12:14 PM
IvanKV's Avatar
IvanKV
Ivan
Let me know what you find
Old February 19th, 2014, 12:21 PM
Rovahfarm, PN-NAD500210 $240 plus shipping.
300tdi, start, tdi
300TDI smoking on start up graham Defender Technical Discussions 7 February 2nd, 2017 04:50 PM
300Tdi intermittent start issue - starter or main chassis ground? nathanwind Defender Technical Discussions 30 February 21st, 2015 10:04 PM
HELP 94 d90 will not start ripp2002 Defender Technical Discussions 64 August 25th, 2005 08:43 AM
