300TDi won't start - Page 2 - Defender Source
Old February 19th, 2014, 12:37 PM
IvanKV's Avatar
IvanKV
Ivan
'89 110 County - 200TDi
Well she started today.
I moved a weird metal stick thing that was on the rear of the radiator, I doubt they are related.
Old February 19th, 2014, 02:02 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Could be the relay on the starter sticking as well.
Legend in My Own Mind.
Old February 19th, 2014, 02:17 PM
IvanKV's Avatar
IvanKV
Ivan
Annnd we are back to not starting...
I try the key, the lights dim, radio goes off, there is a click sound from the passenger foot well and nothing from the engine.
Going to push start it tomorrow after classes and take it too my local LR shop, he said he would diagnosis the problem. Then I can fix it this weekend
Old February 19th, 2014, 02:23 PM
You should be parking facing downhill....
Old February 19th, 2014, 02:25 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
When the motor does not turn over, is it noticeably colder at that time.
Old February 19th, 2014, 02:30 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi Ivan,
I'm assuming its a manual trans, if when you turn the key you get nothing I would try holding the starter relay you should feel it bump slightly as it engages if it don't try pulling it and re-seating it in case the contacts are corroded, if you can feel it bump try removing and reconnecting the starter cables at the starter solenoid - dis-connect the battery 1st.!!
to test the earth connection when it is not starting clamp a jump lead to the engine and then to battery -ve then try starting.
a quick check see if it's a bad connection in the starter solenoid is to put headlights on and try to start it, if the lights dim then current is getting to the starter but the contacts are bad - easy to clean with basic toolkit and some common sense.
still problems - buy a cheap test lamp and we can go from there.
regards all
Gren
Old February 19th, 2014, 02:31 PM
IvanKV's Avatar
IvanKV
Ivan
This is Oklahoma...what is a hill?
Old February 19th, 2014, 02:34 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Ivan you've covered some of my points while i was 1 finger typing my diatribe.. looks like bad starter solenoid.. about 14 replacement here
regards
Gren
Old February 19th, 2014, 02:45 PM
IvanKV's Avatar
IvanKV
Ivan
regards
Gren
Cheers! Will order one
Old February 21st, 2014, 10:30 PM
IvanKV's Avatar
IvanKV
Ivan
It was a bad relay, all sorted.
Thanks for the help and suggestions.
Cheers!
300tdi, start, tdi
300TDI smoking on start up graham Defender Technical Discussions 7 February 2nd, 2017 04:50 PM
300Tdi intermittent start issue - starter or main chassis ground? nathanwind Defender Technical Discussions 30 February 21st, 2015 10:04 PM
HELP 94 d90 will not start ripp2002 Defender Technical Discussions 64 August 25th, 2005 08:43 AM
