300tdi wiring harness?? - Defender Source
Old February 11th, 2013, 09:19 AM
kim's Avatar
kim
kim knotts
1994 d-90 300 tdi #199
installing a 300 tdi engine in D-90 the harness that came with it is fried.
Does anybody know where or who makes new harnesses?
Have tried RDS and some others, but have come up dry.
kim
Old February 11th, 2013, 09:37 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Is it the engine harness or the bulkhead one?
the engine harness you can get new from autosparks.com in the UK, but I am sure there are some used ones floating around here.
But the main bulkhead harness you will be very pushed to find an early one that is not fried, I have got four that all had the main 12v power (white wire) burned which burns the ones touching it the loom.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old February 11th, 2013, 10:05 AM
kim's Avatar
kim
kim knotts
I think I will be needing both by the end of the day.
The D-90 is a 94 and the engine is a early 90 (best guess)
Will check out the link
Thanks again
kim
Old February 11th, 2013, 10:26 AM
http://www.autosparks.co.uk/index.ph...fag6o8m4gajgk3
Old February 11th, 2013, 10:33 AM
navydevildoc's Avatar
navydevildoc
Neill Thornton
As far as I know Autosparks doesn't have any engine harnesses for anything past the 200tdi.
Old February 11th, 2013, 10:41 AM
kim's Avatar
kim
kim knotts
Thanks for the info, the quest continues!
Old February 11th, 2013, 10:43 AM
Ah OK... some just say "diesel"
Old February 11th, 2013, 11:12 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Assume you had a V8 and unplugged the whole 9 yards from the main loom complete with ECU.
Please confirm.
RDavisinVA
Old February 11th, 2013, 11:19 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
We can get new ones:
AMR3483 - Engine harness 300tdi
AMRXXXX - I need to find the number for the 90 (all i have is the 110/130 numbers on hand)
Engine/Main harness is a little pricy, the rear/chassis harness isn't.
I may have a used one floating around the shop somewhere, not sure on the condition though.
Old February 11th, 2013, 12:14 PM
kim's Avatar
kim
kim knotts
Robert,
I pulled everything out
kim
Old February 11th, 2013, 12:39 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Give British Wiring a call.
Old February 11th, 2013, 02:27 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Define everything????????????
Originally Posted by kim View Post
Robert,
kim
Please be more specific.
RDavisinVA
Old February 11th, 2013, 03:37 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
If you just need an engine harness for a 300 Tdi you can make one easy as the motor doesn't require very much. You will need a switched power for the injection pump, Oil pressure sending unit, water temperature, alternator and starter. You can get everything but the switched power from your existing harness. If your are planning on running your glow plugs then you will need to add that too.
Did you try Safari Heritage parts for a harness?
Land Rover 110
Old February 11th, 2013, 05:19 PM
kim's Avatar
kim
kim knotts
ok,
removed original engine and lighting harnesses from the engine compartment. This includes the lighting, horn and extra driving and fog lighting on the bumper.
removed cpu, the plug and it's harness is still in place.
kim
Old February 12th, 2013, 08:01 PM
Capt Milks's Avatar
Capt Milks
On a ROW truck the wing lighting harnesses are separate and connect at a plug on the engine side bulkhead firewall. You can get a wiring diagram for the NAS stuff and trace the wiring colors at the firewall plugs. You will have a bunch of extra stuff that the V-8 required that a diesel doesn't.
Land Rover 110
Old February 12th, 2013, 10:28 PM
Turbofan's Avatar
Turbofan
Ethan
'73 SIII/ D90 Hybrid
Run the wire that controlled your coil to the fuel solenoid, use the existing coolant temp, oil pressure light and alternator wires. Like it was said, all you really need to do is add the glow plug relay (which has its own harness).
Why make more work for yourself?
Old February 12th, 2013, 10:39 PM
Thanks again
kim
first year for the 300tdi was 93.
300tdi, tdi, wiring
Needed - ST Roll bar pieces, dash 300TDI wiring harness CDeWan Wanted 5 July 9th, 2009 03:08 PM
Stereo Wiring Harness Manufacturer? priest944 Defender Technical Discussions 7 January 11th, 2005 06:03 PM
90 main wiring harness & TDI engine mounts TDI Guy For Sale - Parts 5 December 13th, 2004 01:45 PM
Trailer Wiring Harness Weldon Defender Technical Discussions 17 August 26th, 2004 12:03 PM
300tdi Wiring Diagram? JimC Defender Technical Discussions 20 April 7th, 2004 09:39 AM
