300Tdi VDO Help - Defender Source
Old June 3rd, 2016, 12:53 PM
300Tdi VDO Help
I'm planning on adding an oil pressure gauge and boost gauge to my 300Tdi and want to be sure I order everything i need the first time.
0-80PSI Gauge 350-104
Sender 360-006 w/ M10x1K thread
30 PSI Boost Gauge 150-104
Adapter: M12 X 1.5 X 1/8 NPT
Is the thread correct and do I need a spacer?
I have read two different things regarding the thread and pitch.
Lastly which tubing for the boost gauge did you have success with?
Thanks all!
Old June 3rd, 2016, 01:05 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Dave, I used to have a 0-30 boost gauge too, but replaced it with a 0 to 20. You'll never push 30 even if you greatly modify things.
With a lower & more accurate (sensitive) gauge you will need to insert a 1" piece of a #6 screw to keep the needle from bouncing from the engine pulses of the pressure.
Old June 3rd, 2016, 01:06 PM
So a 15 PSI gauge? VDO come 0-15 or 0-30. I don't plan on pushing the motor, I just want to know what's going on.
Old June 3rd, 2016, 01:23 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Well 1 bar of pressure is 14.8 psi, that's why I went with Westach they make a 20 psi and looks very similar to VDO.
Westach is aircraft quality stuff, they're main customers.
They had to build mine, but it's a regular item for them, not custom.
Just did my latest opacity test here on the dyno, 0.2% and we're allowed 40%
Old June 3rd, 2016, 01:33 PM
I'm trying to stay all VDO. With that said I'm thinking 15 PSI should be fine (since I'm not going to crank up my motor settings) but I'm hoping somebody with a VDO gauge setup will chime in.
Also can anybody assist with my oil pressure sender questions?
Old June 3rd, 2016, 02:46 PM
Greenbull's Avatar
Greenbull
Mark Miller
1994 Defender 90NAS #1258
Dave,
Have vdo in both rrc and d90! A pillar on classic and raptor console in defender. 15 psi in both!
Look and work great!
Old June 6th, 2016, 12:32 PM
Whiesel's Avatar
Whiesel
Eric Williamson
LR-90 300 tdi
Dave,
Here are a few pic that might help you.
The VDO oil pressure sender that I used was 1/8 NPT. You also need a nipple and tee so you can retain your oil pressure light switch.
Rerouted boost pressure hoses to the manifold. Wastegate, FIP, and boost gauge. The plumbing bits looks a bit naff, but works, I may fashion a suitable manifold.
For the connection to the manifold I drilled and tapped 1/8" NPT the existing plug (there is just enough meat) as the one I received from MadMad did not fit.
You will need Loctite thread sealant.
I have a 15 psi VDO Cockpit, but boost with the VNT spikes at 17.
With a gauge this sensitive you will get needle flutter that can be fixed with the screw as mentioned or an orifice (snubber)
Question from me to the Community - I cannot find a supplier of a cobra head silicone elbow 1 3/4 ID. There is not much clearance to the inner wing on my VNT set-up. The cobra heads are intended for tight radii while optimizing flow.
Eric
ID:	151077   Click image for larger version
ID:	151079   Click image for larger version
300tdi, tdi
Vdo gps sender and vdo electronic vision plus speedometer Werrea Defender Technical Discussions 6 April 20th, 2015 05:18 PM
Tdi VDO oil pressure sender help Uncle Douglas Defender Technical Discussions 15 August 1st, 2014 12:08 PM
VDO gauges - help Mrenkil Defender Technical Discussions 4 May 17th, 2012 11:38 PM
VDO Speedo help timtimtj Defender Technical Discussions 6 October 24th, 2010 10:16 PM
Need help with VDO airbornrover Defender Technical Discussions 1 November 6th, 2007 12:09 AM
