300Tdi valve ajustment question... - Defender Source
Old September 2nd, 2006, 08:01 PM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
I need to do a 1000 mile valve adjustment...do I do it cold or hot engine?
any watch outs? (like, the damn thing won't start up if I move the crank for getting the valves in position, will it?) Thanks for any input...
George
Old September 3rd, 2006, 08:21 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Cold
No...I've never had one start.
It's important to hold your lips just right when adjusting the exhaust valves
Matt Browne
Old September 3rd, 2006, 01:30 PM
Gkase's Avatar
Gkase
George Kase
thanks Matt...is it ok to reuse the valve cover gasket? (onlly 1000 miles) or if I need a new one do use any kind of sealer?
Old September 4th, 2006, 07:14 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
I'd reuse the gasket for sure, clean and dry. I'd Replace it at about 12,000 miles (or 400 hrs). That gasket is one of those things that you should have in your spares kit.
Matt Browne
Old September 4th, 2006, 09:00 AM
Gkase's Avatar
Gkase
George Kase
thanks Matt...by the way...for others needing to do this, I found a bunch of good hints thru google that can save some time like advancing the valve train with the alternator pulley nut instead of the crank pulley ( so no need to remove fan shroud etc.)...thanks again!
George
Old September 4th, 2006, 10:21 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I never adjusted mine yet.. I have 6k on the truck. Should I? I did not think it was nec. at 1000
Legend in My Own Mind.
Old September 4th, 2006, 10:54 AM
Um, I havent adjusted mine and I'm at almost 40k...
Old September 4th, 2006, 11:53 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
lol... ok good. im not the only one
Old September 4th, 2006, 12:15 PM
Gkase's Avatar
Gkase
George Kase
M&D told me to change the oil and adjust the valves at 1000...but, hey, who am I to buck a trend?
Old September 4th, 2006, 12:18 PM
I changed the oil for the first time at 6k, and as mentioned, havent touched the valves.
Old September 4th, 2006, 09:24 PM
junkyddog11
oil soaked filter
95 RRC 300tdi
should adjust at about 12k.
Never tried turning the crank with the alternator....then again I've never had to remove the fan shroud to turn the crank either?
I generally do maintenance according to engine hours not by mileage. www.tinytach.com/tinytach/diesel.php
Matt Browne
Old September 5th, 2006, 07:27 PM
Gkase's Avatar
Gkase
George Kase
Thought I'd post results...simple to do...just like all my old MGB/TR3/etc...sounds smoother and quieter...worth doing.
Hey Matt...thanks for mentioning that Tiny Tach...I'm going to pick one up...also, the alternator bolt didn't work (belt slippage)...you can reach the crank pully from up top without removing shroud? how you do that?
Old September 6th, 2006, 06:47 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
Not sure how I reach the crank pulley from the top as I don't have a truck in front of me right now, I just know for sure that I haven't pulled the fan shroud off to adjust valves, which is at worst a 45 min job. Pulling the fan shroud is a pain in the ass.
I'll try to remember to look when I get into the shop.
Matt Browne
Old September 6th, 2006, 08:50 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
A socket on a 1/2" socket wrench slips in between the pulley and the shroud from the bottom. Sometime you have to put the socket on the bolt, then attach the wrench to it once that is in place, but Matt is right, no need to pull the shroud. It is tight, but it is easier than pulling the shroud. Never tried it from the top as that would mean taking the clutch fan off.
Email:
Old September 7th, 2006, 06:37 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
You can also sneak it (the socket on a breaker bar)in from the injection pump side if you hold your lips just right. Then you can watch the valve train move, helpfull if you are working solo.
Matt Browne
Old September 7th, 2006, 08:19 AM
Gkase's Avatar
Gkase
George Kase
yup, that's how I did it, from the bottom...but that required having someone else doing the wrenching from below...next time I'll try the injection pump side...thanks all!
Old September 7th, 2006, 09:27 AM
ECR's Avatar
ECR
Most of the ones I work on have AC and that puts the squeeze on reaching from the injection pump side. Of course if you are alone you can take the clutch fan and shroud off and do it the "proper" way.
Email:
Old September 8th, 2006, 03:57 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
According to "revue technique automobile" and haynes manual, valve
adjustment must be done every 10,000 kms (+/- 6,000 miles), setting is
0.20 mm on all valves, engine has to be cold. Does anyone use the
wheel lifting and 5 gear method to move drivetrain ?
- Charles Eames
Old September 8th, 2006, 09:20 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Take 'em to school JFD. Put it in difflock. Jack up a front tire and turn the tire with it in gear to turn the engine over. Old school, I like.
I myself just take off the fan and clutch without removing the shroud. Then turn the engine over from the engine bay with a rachet end on my long breaker bar. But I am Pendy. You can do this on A/C equiped engines if you hold your mouth right as well.
I also adjust by rule of nines. Valve overlap. If one is down adjust eight. If two is down adjust seven and so on. Front is one, back is eight.
JP
legend in my own mind
Old September 9th, 2006, 08:00 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
Schooled my ass........
I say 12k 'cause I've yet to have to adjust one at 6k or 8k or 10k and barely had to adjust at 12k.
But I have checked them.
9's are the way for sure
I would have to think that "old school" turning the fawkin tyre to move the valve train would be even more challenging than holding your lips just right.
However it's allways nice to know the "correct" way of things, much appreciated.
Matt Browne
300tdi, tdi
300Tdi Radiator question Lyman Defender Technical Discussions 4 May 10th, 2008 06:08 PM
300Tdi AC question Gkase Defender Technical Discussions 8 September 13th, 2006 03:07 PM
NAS D90 300tdi exhaust? Chris Cox Defender Technical Discussions 19 June 13th, 2006 04:59 PM
question about installing 300Tdi kit from M&D? Gkase Defender Technical Discussions 12 May 24th, 2006 08:36 PM
