300tdi turbo started making a noise - Defender Source
Old October 29th, 2012, 08:07 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
The turbo on my 300tdi just started making a strange noise. When it initially engages it sounds normal but if I step on it there is a loud hissing noise. I haven't popped the hood yet but I'm guessing its either a hose leaking and pressure escaping or perhaps a bearing going bad? No clue what I'm talking about though, just guessing. Should I be worried?
Old October 29th, 2012, 08:15 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
Is it smoking upon acceleration more than usual? Check the hoses going to the intercooler and from the intercooler, it sounds like you have a boost leak somewhere, I've had it happen in my vw tdi a few times, if you ignore it the hose will slice open more and you will lose power. If its a boost leak then it is nothing to worry about, i drove a couple hundred miles to waterfest and commuting before i got my replacement hose. I taped up the hose to help retain some boost.
Old October 29th, 2012, 09:30 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Check for proper lubrication.
- Charles Eames
Old October 29th, 2012, 09:36 PM
sounds just like boost lline eak. hissing is not a sound I've associated with a failing turbo.
Mark Kellgren
KM4BOR
Old October 29th, 2012, 09:49 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Pretty sure it's the hoses. I did the timing belt not too long ago and those silicone intercooler hoses sure are slippery. May not have retightened them enough.
It only happens at higher speeds and higher boost pressure. Haven't checked for excess smoke because I already have excess smoke. Need a timing tune up after the belt change but haven't gotten to it.
Lube? Where exactly?
Old October 29th, 2012, 09:58 PM
JohnsD90's Avatar
JohnsD90
Higher pressure means the air will escape faster, and will result in the louder whistle, its one of your hoses, if you didn't tighten it enough, thats even better, its a free fix!
Old October 30th, 2012, 08:14 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I had one that seemed to have a higher whistle sound while the turbo was spooling up. It was much louder than the others. It turned out to be the turbo bearing going bad.
Land Rover 110
Old October 30th, 2012, 11:59 AM
To check for leaks, Shopvac blower to the turbo inlet.
Old October 30th, 2012, 06:27 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Problem solved. Not sure how it happened but I lost the hose clamp that attaches the silicone hose to the intercooler. It can't slip off but at higher pressures it would leak. Buying another one today.
300tdi, start, tdi
VNT Turbo kit for 300Tdi.....Worth it? jrose609 Defender Technical Discussions 40 August 17th, 2016 07:57 AM
DIY VNT turbo for 300TDI? jaherring Defender Technical Discussions 47 August 15th, 2013 07:26 PM
FS: good take-off 300Tdi turbo, manifold, and downpipe jrose609 For Sale - Parts 8 May 23rd, 2012 11:15 PM
300tdi exhaust and turbo. millerhlyf Wanted 2 March 29th, 2011 11:31 AM
