300tdi turbo pressure line plumbing - Defender Source
Old March 13th, 2015, 10:21 PM
Blake's Avatar
Blake
Blake
1997 90 Wolf
Question 300tdi turbo pressure line plumbing
Hey Everyone,
Been a bit of a lurker here for some time and now find myself with a question I haven't been able to figure out.
I recently picked up a RHD 1997 Wolf 90 with the 300tdi and was looking to put in a boost gauge - my original plan was just to tee it off of the charge pressure line running to the fuel injection pump, when I was following that back I found that there was a tee just prior to the fuel injection pump that also ran to (from my cursory glance) looks like the timing cover and connects to a banjo bolt. I haven't been able to find anything in my parts manual or workshop manual relating to this - any ideas?
Unrelated question, is there ever anyone looking for military radio mounting bits? I have a bunch I pulled out that I have no interest in (pic below).
Cheers,
Blake.
Old March 14th, 2015, 09:40 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
I connected onto the intake manifold. There is a plug there that can be removed.
The treading of that "hole" can be found from a board member here, named "Broncoducer"
PM him or look through his threads.
He recently did one on his 300Tdi.
Old March 14th, 2015, 09:51 AM
Yep, most people connect directly to the manifold. It is a better place to measure.
If you are looking for any local help ask over on the local forums. Alberta Land Rover Enthusiasts Club Forum - Index
Old March 14th, 2015, 11:26 AM
Broncoduecer's Avatar
Broncoduecer
peter
D90
The manifold thread is m12-1.5.
I bought this off amazon: http://www.amazon.com/gp/product/B001DKM4PU/
I am running an edge CTS for all the gauges and rear view camera.
Old March 14th, 2015, 09:46 PM
BullTrout14's Avatar
BullTrout14
1985/Defender 110
Thanks for that great timing just looking at installing my McNally EGT/Boost guage and that looks much easier than tapping my manifold.ordered the same kit today!
Cheers,
Old March 14th, 2015, 10:28 PM
Blake's Avatar
Blake
Blake
1997 90 Wolf
Thanks guys, I never noticed that blanked port either. Any one figure out what that last tee by the fuel injector runs to?
Old March 16th, 2015, 12:14 PM
Blake's Avatar
Blake
Blake
1997 90 Wolf
Well I did the timing belt this weekend which required taking off the banjo bolt fed by the pressure line from the turbo, turns out it just has a 0.020" hole in the banjo bolt - likely to prevent hydraulic hammering or just smooth out the pressure signal to the fuel injector pump.
300tdi, tdi
ROW 300 Tdi fuel tank/plumbing Mark McDonough Defender Technical Discussions 22 August 6th, 2013 03:59 PM
Front brake line - why hard line & flex line? jefhuf Defender Technical Discussions 5 January 13th, 2012 09:03 AM
Factory A/C plumbing and heater matrix? fraser61 Defender Technical Discussions 2 December 28th, 2010 08:14 PM
Plumbing Tank/Circulation Heater 200TDI ajh Defender Technical Discussions 12 December 19th, 2010 12:11 AM
Gas tank plumbing (vapor vent lines) redrockrover Defender Technical Discussions 3 September 2nd, 2008 12:01 PM
