300Tdi Troubleshooting (again) - Page 2 - Defender Source
Old July 9th, 2013, 06:04 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Mystery Solved.....
Old July 9th, 2013, 06:05 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Oh dear hope it's not too serious.
Mike Hammond
Old July 9th, 2013, 06:08 PM
Originally Posted by navydevildoc View Post
Mystery Solved.....
Even I'm relieved it was something simple...if you had another head gasket issue I would have lost faith myself .
Old July 9th, 2013, 06:19 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Originally Posted by JFD View Post
First thing you should check is valve clearance, may be a push rod nut came loose.
So am I a voodoo master or what ?
- Charles Eames
Old July 9th, 2013, 06:28 PM
navydevildoc
Neill Thornton
Hahaha... maybe a brujo?
Old July 9th, 2013, 06:39 PM
navydevildoc
Neill Thornton
Parts ordered from Paddock. Rovers North wouldn't be able to get them for almost 2 weeks before shipping to me, and I waited on hold with Atlantic British for 20 minutes before giving up.
I really miss having British Pacific.
Old July 9th, 2013, 06:46 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Did you try www.lrdirect.com ?
- Charles Eames
Old July 9th, 2013, 07:00 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Process not described, but point is probably moot.
Saw the clip with broken rocker bolt, so describing the process you used to torque your head is probably moot at this time, but did not see any technical data that you posted on those links, but could have missed it as there were lots of posts to go through.
For example torqued the xxmm bolts 60, 30, 60 degrees and waited 3 hours between each torque and followed this order. Torqued the smaller xxmm bolts 60, 30, 30 degrees blah blah yadda yadda... Had the engine block resurfaced with a light skim of 2 thou. Head was checked and 2.5 thou removed to make it flat... and so on.
Am still at work, so don't have a manual in front of me to be exact. At least one of the published shop manuals have incorrect degree specs for torquing the head bolts. That was the info I was looking for just to double check your process and perhaps help from that approach.
Sorry you had an issue, but at least it looks like a simple repair... good luck.
RDavisinVA
Old July 9th, 2013, 09:16 PM
navydevildoc
Neill Thornton
Oh, I am extremely anal about the head procedure. It was followed to the Ts every single time.
Old July 9th, 2013, 09:29 PM
navydevildoc
Neill Thornton
No... Paddock as been good to me, as has Britcar. Never used LRDirect before... but I do like their interface. I already have Microcat so the part numbers are easy to get.
Old July 9th, 2013, 10:01 PM
Originally Posted by down_shift View Post
Why would you ever reuse head bolts? Stretch or torque to yield bolts are single use only.
Not all TTY bolts are single use.
300tdi
NAS D90 300tdi exhaust? Chris Cox Defender Technical Discussions 19 June 13th, 2006 04:59 PM
300Tdi wings/ radiator finisher (defender) Lyman Wanted 2 March 8th, 2006 05:51 AM
94 D90 wagon, 300tdi for sale Chris Cox For Sale - Vehicles 20 November 9th, 2005 12:43 PM
1995 Discovery 300TDI, Trail Ready.... Joe B For Sale - Vehicles 1 June 23rd, 2004 06:26 PM
