300tdi to r380 bellhousing fasteners? - Defender Source
Old January 9th, 2016, 02:21 PM
SkinlessFrank
Sean
1984 Defender 90 (2.5 TD)
Stupid help needed. I need to know the ~correct~ nut and bolt sizes/grades needed to reattach the transmission to the engine. I assume Lowes or Napa should have these...
Over a year ago, I boxed everything up...labeled properly...when DHS carted off my truck with my recently installed-then removed Disco drivetrain. I finally started to reinstall my new-to-me drivetrain and now cannot find my parts. I had to move everything twice (3 sets of drive trains, electronics, and various Defender, Disco, and series parts), and it appears that some things are MIA.
I checked the FSM, but 2 hrs later I am coming up empty. Any help is appreciated with this...I will upload Picts in just a bit to illustrate.
Sean
Old January 9th, 2016, 02:28 PM
SkinlessFrank
Sean
Originally Posted by skinlessfrank View Post
stupid help needed. I need to know the ~correct~ nut and bolt sizes/grades needed to reattach the transmission to the engine. I assume lowes or napa should have these...
<snip>
...i will upload picts in just a bit to illustrate.
sean
Old January 9th, 2016, 03:01 PM
Sizing is shown in the parts catalog.
http://www.allbrit.de/UNI.cfm?PAGE=749047&SPRACHE=EN
Old January 9th, 2016, 03:50 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
You will need some M10 flanged nuts (you will need a 15 socket spanner) , some of these bolts listed inside the first link and 4 longer M10 screws than listed there. These are used for the connection between the engine bracket and the bellhousing. All M10 bolts have a flanged head driven by a 13mm socket!
I guess it was M10x60mm for these 4 longer bolts.
Maybe 65 in length.
Have a look at the flat side of the screw's head: they should show you an 8.8 sign, useable nuts should show you only an 8! Studs have the longest part of all of the three versions sold in Europe to be screwed inside the aluminum part! Followed by these to be used inside cast iron. Shortest version is to be used inside steel!
Good luck with the classification of bolts.
Old January 9th, 2016, 03:52 PM
SkinlessFrank
Sean
Ok...looks like all m10 either 30 or 35 long for bolts/studs and m10 for nuts. Grade 5, I assume?
S
------ Follow up post added January 9th, 2016 03:58 PM ------
Maybe 65 in length.
Roger that...thanks for the details.
No 8/8.8 anywhere that I can see, but will follow your 411.
:D
Old January 9th, 2016, 04:25 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Anytime I work on removing or installing any rover engine, the first thing I do is remove those gaud awful studs and replace them with bolts.
10mm X 1.6 X 30mm is what is needed.
You should also get 4 long bolts and put one in each "corner" to guide the engine and gearbox together and keep everything level.
RDavisinVA
R380 + 300Tdi bellhousing Talleyrand For Sale - Parts 4 July 11th, 2015 07:56 PM
Defender 300Tdi Bellhousing for R380 Gearbox Chip For Sale - Parts 3 March 25th, 2015 05:52 PM
WTB: R380 transmission for a 300TDI with bellhousing and shifter Mike Sandone Wanted 1 September 13th, 2011 06:51 PM
300 TDI R380 Bellhousing SafariHP The Vendors Loft 0 October 16th, 2008 10:00 AM
bellhousing R380 for 200 Tdi metric Wanted 0 June 8th, 2008 02:20 PM
