300tdi Timing belt tracking - Defender Source
Old September 15th, 2010, 05:34 PM
On the 300tdi there is a chance your timing belt may not track straight, resulting in premature failure. Various parts and kits are available to make sure this does not happen. Once you are done you can check things out by running the motor with the timing cover off:
ID:	31124   Click image for larger version
ID:	31126   Click image for larger version
Old September 15th, 2010, 05:59 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
I would assume this would not be something you would want to try with a 200tdi since the water pump has to be removed when you remove the timing belt cover?
Old September 15th, 2010, 08:19 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I may have missed something, but that wasn't your motor was it?
Semper Fi!
Old September 15th, 2010, 10:08 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
Any "parts and kits" you are aware of to get it to track better??
How many miles before you accumulated that much rubber shavings in the case?!?!?!
What did you do to prevent that from happening again??
Old September 15th, 2010, 11:31 PM
The photos are of the motor that is now in my truck, and were taken in July of last year before I installed it. The one in the video is a different motor. At the time I did mine I did not know of running the engine this way.
I fitted the upgraded crankshaft timing gear, tensioner, and idler pulley that make up the basic kit to prevent the belt walking off. They did away with the shoulder that used to be on the tensioner and put it on the crank gear. There is also a different bracket for the injector pump that slightly changes its position to also aid in preventing belt misalignment. I have that bracket, somewhere...
The engine in the video had no signs of belt issues at all, but was changed due to lack of service history on the vehicle.
I don't think the 200tdi engines have the issue of the belts walking off.
Old September 15th, 2010, 11:32 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
nope, mine - new timing belt, tensioner, idler (the kit from Eric @ Atlantic British see this thread -> http://www.defendersource.com/forum/...ad.php?t=26123), an oil seal on crank pulley inside of the timing cover, silicone intercooler hoses (also from Eric -> http://www.defendersource.com/forum/...ad.php?t=25927) and new radiator hoses.
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
300tdi, ac, rack, tdi
300TDI Timing belt kit brn24whl The Vendors Loft 7 June 23rd, 2010 09:40 AM
300tdi timing belt change now problems discotdi Defender Technical Discussions 57 June 4th, 2009 10:10 PM
US source for 300tdi timing belt tool kit D90user Defender Technical Discussions 5 September 5th, 2006 05:35 PM
300tdi timing belt check? D90user Defender Technical Discussions 6 April 5th, 2006 07:24 AM
