300tdi Timing Belt Change - Page 3 - Defender Source
Old March 4th, 2012, 02:27 PM
with the puller that uses the small 5mm bolts
Old March 4th, 2012, 03:05 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
My timing kit didn't have 5MM so I bought 5MM threaded rods and used the puller.
Next. How do I get the oil seal out without scratching any of the surfaces? Looks like in addition to the oil seal there is also a large O-ring (ERR4710?) that i assume should be replaced?
Old March 4th, 2012, 03:54 PM
Originally Posted by Manimal View Post
The old crankshaft sprocket is really stuck in there. How do I remove it without completely destroying it?
I posted a thread on this a month or two ago. I couldn't find any 5mm bolts that were strong enough so I drilled it out and tapped it for 6mm (?) bolts that I already had with a puller set.
Old March 4th, 2012, 04:21 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
The sprocket was easy once I got the 5MM threaded rods. Came right out and didn't have an issue with the strength. Now, the seal is giving me a hard time. Going to store to get an oil seal puller.
Old March 4th, 2012, 05:18 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Well I guess that concludes today's session as I ruined the only replacement oil seal I had available while trying to put it in. It appears that a dry seal is not the way to go. What should I lubricate it with? Grease? I'm going to have to order new seals from the UK. Does anyone have a ERR4575 handy that they could throw in the mail for me?
I got a Oil Seal Puller from the Auto store. I have to say that it is very difficult to remove the seal without denting the edge of the alloy casing. Not sure how you guys go about it. Is there a secret trick?
Old March 4th, 2012, 06:49 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Try the dealer first. It is funny what they have and what they do not for the 300. You could also try George at RDS or Stephen at Safari Heritage, for that matter Pendy might have one lying around.
Land Rover 110
Old March 4th, 2012, 07:24 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Try Trevor at RovahFarm, he told me he'd stock some. May take a phone call.
http://rovahfarm.com/
PS. RN probably has them but they're gonna beat you up pretty hard for a $2 item.
Old March 4th, 2012, 08:42 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
The Stealership is not a bad idea. I will call them in the morning. I already placed an order from LR Series but if Trevor, etc can send a seal without charging me $10 in shipping then that would be the way to go.
Old March 5th, 2012, 01:46 PM
I think I tried to get a crank seal and they were market specific. LRNA does stock 300 tdi water pumps though!
Old March 5th, 2012, 01:55 PM
Yes, completely coat the seal with grease. Also lubricate the shaft with grease. Synthetic, natural, or moly works. Do not use antisieze compound.
I once tried putting in a seal without grease, and it cut the seal lip. It ended up leaking worse than the old seal that I removed
Old March 5th, 2012, 03:11 PM
Do you mean the dealership carries waterpumps for a 300Tdi? I find this incredible if I'm reading it right.
Old March 5th, 2012, 09:24 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
That's what I did. There is no way to get that in there without lube and they are fragile too!
Why lubricate the shaft? It doesn't seem like it would need it.
Old March 5th, 2012, 09:25 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I called this morning. The stealership in Portland doesn't carry anything related to diesel.
Old March 5th, 2012, 09:36 PM
Capt Milks's Avatar
Capt Milks
Yep, Just got one from LR Richmond a couple weeks ago. The national inventory was getting low when I got mine. They had one or two left. Who knows if they mis-ordered or what, for why they had them. I had also checked on the long water pump bolts but they did not have them. Had to get them from the UK.
Land Rover 110
Old March 5th, 2012, 09:46 PM
The 5mm's I bought only came in a single thread pitch and were only available in cap/allen head grade 8.
Did you find a starter Jimmy ?
Old March 5th, 2012, 09:55 PM
I do it because I always end up touching the seal against the shaft as it goes on - no need to grease the whole shaft, just the part that the seal touches.
Old March 5th, 2012, 10:00 PM
Ummm...."that's what she said"?
Old March 5th, 2012, 10:13 PM
Ron Mexico
Ryan
LR3
Did you call PDXRovers or Columbia?
When I was looking for an LR4, the guys at LR Portland weren't much help at all, for anything.
Old March 6th, 2012, 11:22 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
George @ RDS to the rescue. I will have a seal in hand Friday and only $5 shipping. George is the man!
I didn't bother with Columbia or PDX as they haven't been very diesel friendly in the past. In fact, I've never been to PDX Rovers. I contacted them once and never heard back so that was the end of that. Shipman is the only one I trust with diesels.
Old March 6th, 2012, 04:40 PM
Ron Mexico
Ryan
LR3
We'll have to talk about this soon enough, I'll send you a message!
300tdi, tdi
300Tdi Timing belt failure and repair.. TDI Guy Defender Technical Discussions 46 November 11th, 2010 12:53 PM
shop to change timing belt 300tdi - DC Metro area hillstrubl Defender Technical Discussions 17 July 19th, 2010 06:39 PM
300tdi timing belt change now problems discotdi Defender Technical Discussions 57 June 4th, 2009 10:10 PM
300tdi timing belt check? D90user Defender Technical Discussions 6 April 5th, 2006 07:24 AM
