300tdi time for oil pressure - Defender Source
Old April 10th, 2015, 01:38 PM
Blake's Avatar
Blake
Blake
1997 90 Wolf
Hi everyone,
Quick question (hopefully) - my 300tdi I takes about 3-5 seconds after starting for the oil pressure light to go out on first start. After it's run and turned off oil pressure light goes out immediately after starting again. Normal, problem, likely cause?
Old April 10th, 2015, 02:47 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
What weight oil are you using ?
How cold is your ambient air temperature where the vehicle is parked over night ?
Old April 10th, 2015, 02:50 PM
Blake's Avatar
Blake
Blake
1997 90 Wolf
I currently have 0w40 in there, right now it's typically 0-5C overnight, generally colder prior to April (-10 to -25C).
Time to change to a 10w40?
Old April 10th, 2015, 03:35 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
What filter are you using? You should try to use one with an anti drain back valve or flap.
Black Rhino Lives Matter
Old April 10th, 2015, 03:38 PM
Blake's Avatar
Blake
Blake
1997 90 Wolf
I have a factory land rover filter. The release at the bottom of some filters is a bypass in case the filter becomes clogged etc.
Old April 10th, 2015, 03:58 PM
I will say that is not normal. You are either having a drain back issue or your oil pressure is marginal all of the time. I would at least temporarily hook up a oil pressure gauge to see which it is.
Old April 10th, 2015, 04:42 PM
Blake's Avatar
Blake
Blake
1997 90 Wolf
Guess I'm ordering a pressure gauge. M10x1 for the sender unit right?
Old April 10th, 2015, 05:01 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
Yep you got it
Robert had a great thread on this:
http://www.defendersource.com/forum/...uge-60823.html
Old April 11th, 2015, 03:08 PM
clivecottrell1943
Clive Cottrell
Land Rover 90 TD 1989. Discovery s
My oil pressure light was coming on at low RPM. So changed the sender unit. After that OK. I know that does not directly coincide with your problem, but another thing to consider. Cheap and easy to fit....
Old April 11th, 2015, 03:31 PM
Blake's Avatar
Blake
Blake
1997 90 Wolf
Yea, I ordered a vdo oil pressure gauge that comes with a warning contact as well. With that said I haven't been able to find any reference as to what the stock warning contact lights up. Vdo had 5, 7, and 12psi - anyone know what the stock cut off warning pressure is?
Old April 11th, 2015, 03:43 PM
The only reference I found, 7 psi, PRC 6387,UNIPART PRC6387 Oil Pressure Switch for LAND ROVER,FORD
Old April 11th, 2015, 03:48 PM
Blake's Avatar
Blake
Blake
1997 90 Wolf
That's great, by dumb luck I got the right one. I figured the engine is 20-50psi so anything lower than that should work.
Cheers.
Old April 15th, 2015, 09:41 AM
Blake's Avatar
Blake
Blake
1997 90 Wolf
So, oil pressure gauge showed up and installed. Oil pressure itself is great, up to ~55psi cold, warm it runs around 30psi at idle, up to 50 psi by ~1200 rpm (no tach).
However, as you can see in the videos posted, on cold start there is a delay in oil pressure coming up. One other item I noticed was that the oil level if I check in the morning it seems ~ 300mL high, after running and letting it sit for awhile it's still at the full mark, but by morning it's high again which seems to point to some drain-back through the oil pump with the million dollar question being why.
Watching the video again, it seems it's only about 2 seconds to build pressure though it's still a bit concerning.
Cheers.
300tdi, tdi
oil pressure sender parts for 300TDi TS888 Defender Technical Discussions 1 July 19th, 2011 06:48 PM
sender P/N for factory oil pressure gauge 300TDi TS888 Defender Technical Discussions 4 May 28th, 2011 06:56 AM
Oil Leak..Oil Pressure Switch Failure? tebby Defender Technical Discussions 2 December 19th, 2010 03:16 PM
300Tdi oil pressure spec? crown14 Defender Technical Discussions 5 March 13th, 2009 02:34 PM
Time time has come to name my Defender Hans Misc. Chit-Chat 14 February 8th, 2005 08:54 PM
