300TDI Thermostat Housing Repair - Defender Source
Old March 9th, 2014, 11:18 AM
sjpin
Scott P
I was driving yesterday and steam starting coming from the engine. I stopped and popped the hood. The whole area was covered in coolant. It looks like the top of the plug that is on the top of the thermostat housing broke off and coolant was coming from the new hole. I am a newbie at this stuff. Is there any magic to this repair other than getting the broken plug out and putting in a new o ring and plug? Also, any good suggestions on getting the old plug out? I was thinking of a screw extractor. A picture is below. Thanks in advance.
Old March 9th, 2014, 12:20 PM
Buy a brass replacement ... I would have thought a suitably large screwdriver lightly tapped into the hole would be able to turn that out.
Old March 9th, 2014, 02:57 PM
sjpin
Scott P
Thanks Jason. I got the old one out easily with a screwdriver and I am going to order a brass plug replacement tomorrow.
Old March 9th, 2014, 06:31 PM
Clean it up well and make sure the new O-ring sits well and don't crush it when you tighten the new plug!
300Tdi Thermostat Housing Temperature VS Gauge Viton Defender Technical Discussions 32 May 26th, 2016 01:56 PM
WTB Thermostat Housing o2batsea Wanted 2 April 3rd, 2011 07:28 PM
1994 Thermostat housing sensor timtimtj Defender Technical Discussions 1 December 21st, 2010 07:31 PM
300tdi Air Filter Housing / Hardware GreenRover Wanted 2 July 9th, 2010 07:20 AM
Torque specs for thermostat housing Seanh Defender Technical Discussions 2 August 13th, 2007 10:08 AM
