300tdi Temp Sender Plug - Defender Source
Old April 19th, 2009, 10:04 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Does anyone make a plug that plugs onto a 300tdi stock temp sender? It's a small Nipple thing.. Need to adapt the NAS spade to the tdi sender....
Legend in My Own Mind.
Old April 19th, 2009, 03:59 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
A spade will do, I believe
Old April 19th, 2009, 04:39 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Its not a spade connector on the sender though..
Old April 19th, 2009, 08:02 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
You're right, I just went out an looked at the 300 tdi. I don't know why they did that - the V8, the 200tdi, the 2.5 all use a spade, but the 300tdi has a post. Anyway, I suspect if you try one of those crimp connectors for splicing wires - that would fit. I don't think I have any here at the house, but I'll go look.
Found a blue one and it is too small, but I think a yellow will do the trick.
300tdi, tdi
300tdi temp sender thread?? D90user Defender Technical Discussions 2 March 16th, 2007 03:11 AM
Temp Sender Location DJ Menasco Defender Technical Discussions 10 August 28th, 2006 01:24 AM
95 D90 temp sender range naeirie Defender Technical Discussions 2 April 27th, 2005 12:16 PM
Thread size for temp sender mgrgpg Defender Technical Discussions 3 July 1st, 2004 12:00 PM
LR Glow Plug relay temp? dmarchand Defender Technical Discussions 0 June 9th, 2004 01:42 PM
