300TDI Synthetic or Dino Oil? - Defender Source
Old October 24th, 2010, 10:24 PM
drv2fst
Kirk
Defender
I have a pretty new 300tdi. It currently has about 11,800 kilometers on it. Time for oil change #2. Should I switch to synthetic?
I did search and found nothing with 300 tdi and synthetic.
Old October 24th, 2010, 10:49 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
not necesary imo, change your oil frequently and adjust your valves clearance every 10,000 km.
- Charles Eames
Old October 25th, 2010, 10:47 AM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
can you elaborate on adjusting the valve clearance? - nevermind found some articles -> http://forum.difflock.com/viewtopic.php?t=12920
http://www.landyzone.co.uk/lz/f31/va...0tdi-1545.html
http://www.landroverexpedition.com/t...ve-clearances/
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old October 25th, 2010, 02:32 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
My understanding is dino oil is important for the first 1,500-2000 miles to allow the rings to seat, ie wear.
After that I believe that synthetic is likely best.
Old October 25th, 2010, 09:00 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
These motors are old tech and in my eyes do not need the synthetic oil. The new Cummings in the Dodge recommends dino oil and it has a particulate filter unlike the 3.0L MB diesel which requires a very expensive ESP formula synthetic. It cost me over $100.00, oil and filter, to change the oil in the Jeep CRD (MB 3.0L Motor) I use a high grade diesel oil that helps clean the soot in the 300 Tdi. I just change the oil about every 6,000 miles or yearly.
If older diesels use the sulfur in the diesel fuel to help lubricate what is going to happen when you use the Ultra low sulfur diesel fuel all of the time?
Land Rover 110
300tdi, tdi
V8 Engine Oil - Synthetic vs Semi Synthetic nickt Defender Technical Discussions 68 September 18th, 2016 09:38 AM
Finished the 300TDI swap - some problems/questions jaherring Defender Technical Discussions 10 February 23rd, 2011 01:37 PM
Synthetic or Dino, What do you use??? javelinadave Defender Technical Discussions 16 February 8th, 2005 07:33 PM
