300tdi smoke at neutral throttle - Page 3 - Defender Source
Old October 5th, 2009, 08:18 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
x2
it is full of diesel. so get ready.
BTW there is a heater for the stanadyne head.
Old October 5th, 2009, 09:33 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Thanks for the heads up.
What are the benefits for the optional Stanadyne fuel filter heater? It warms the fuel to prevent clogging. Any other benefits? Just trying to figure out if is worth the hassle of installing.
Old October 5th, 2009, 10:21 PM
D90user's Avatar
D90user
steve
If you live where it is cold and run a bio blend you should at least heat the filter.
if you are thinking about running b100 you will need to heat the whole fuel system if it is cold where you are.
Old October 6th, 2009, 12:14 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Heater it is.
Old October 6th, 2009, 12:28 PM
I have had an FM-100 with 2 micron filter for the last year. Bolts straight onto the stock location. A few compression fittings and it is hooked up. There is lots of height to put in the 6" filter. I have run the 4.3" one and did not have any problems.
If you are going to get a heater, use the top load style, http://www.thedieselstore.com/templa...A31341&VehNum=
Old October 6th, 2009, 03:38 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I was just wondering which heater to get. Thanks!
Old October 6th, 2009, 05:26 PM
D90user's Avatar
D90user
steve
BTW- I just put in a 6in filter and it barley fits...but fits in the stock 300tdi location.
Old October 10th, 2009, 10:53 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Placing my order today.
Follow-up question: when cleaning the sediment filter or swapping out the fuel filter, how do I prime the fuel pump to make sure there's no air in the system?
Old October 10th, 2009, 02:18 PM
D90user's Avatar
D90user
steve
Most likely you will not have to prime. but if you do it is not hard. I think you need a manual... check your PM
Old October 12th, 2009, 12:20 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I disassembled and cleaned the sediment filter today. Good call to open it completely. There was sediment on the bottom that never would have come out by otherwise. No need to prime either. It started right up.
Old October 17th, 2009, 02:17 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
John,
Did you install the top loading heater? I got my parts yesterday but due to poor instructions and a newbie installer I can't figure out what is needed to install the fuel filter heater. Does it need a manual switch or a thermostat? Is it on all the time? Is it hooked up to the ignition?
Old October 20th, 2009, 09:13 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I talked to the thedieselstore.com and resolved the lack of info in the documentation of the fuel heater. It has a thermostat. Below 40 degrees it kicks in so there is no need for a switch.
Hey Steve, do you mind posting a pic of your installed Stanadyne Fuel filter? I'm still not sure what type of fittings I need to get. Also, there are 4 ports on the filter. Shouldn't there only be two? What are the extra two for?
Old October 21st, 2009, 12:43 AM
D90user's Avatar
D90user
steve
Will do.
The two extra holes need to be plugged with a brass plug of what ever size pitch and hole you ordered.
The mounting and fittings are a piece of cake, I got all the fittings at lowes. I will get some pictures by the weekend.
Old October 21st, 2009, 06:22 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Thanks Steve!
Old October 26th, 2009, 10:44 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I adjusted the smoke screw and diaphragm on the injection pump today. 360 degree reduction on the smoke screw and 90 degrees on the diaphragm. I have significantly less smoke now with virtually no reduction in performance. It's about half the smoke at start up now and no smoke when taking off or during boost. I will leave the diaphragm where it is but I might try another 180 degrees reduction on the smoke screw. My suspicions that the previous owner had overdone it on the injection pump adjustments may have been confirmed.
We have a really good diesel lab in town that will test injectors for free. I am considering pulling them out just to have a look at them. It would be nice to know if they are ok or not. Is this advisable? Will I mess with tolerances if I take them out and put them back in?
Old October 26th, 2009, 11:03 PM
D90user's Avatar
D90user
steve
Good on ya.
Pulling the injectors and putting back in is not a problem.
When re installing use a screwdriver as a guide to get them reseated, ie slide them on the screwdriver. put the screwdriver in the whole the injectors go in then let the washer slide down the screwdriver.
When you put the injectors back in dont over tighten the clamp plate... dont ask me how I know.
Sorry no pics yet...no time
Old October 26th, 2009, 11:21 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Great! I will take them to the lab.
Don't worry about pictures. I got the same filter assembly you have (3/8"). How come you didn't reuse the existing (stock) fittings? They will fit won't they? I have attached a pic of my existing filter fittings.
Originally Posted by D90user
Good on ya.
Old December 4th, 2009, 11:54 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I finally got around to installing my Stanadyne fuel filter head. I have attached a couple of crummy iphone snapshots if anyone is thinking about doing the same thing. The 6" filter just about fits with about a 1/4" clearance from the wheel well panel. I had a hard time finding elbow fittings similar to the Bosch filter head so I went with straight ones that had to connect on the other side of the filter. The thing with the wire sticking out on top is the heater which I have yet to hook up. Although there is tight clearance on the side there may be room to fit a water drain reservoir underneath of the filter. So far no problems with the 0.2 micron filter clogging and it is 27 degrees here in Portland this morning.
ID:	23375   Click image for larger version
300tdi, tdi
anyone using hand throttle on 300Tdi? Gkase Defender Technical Discussions 10 December 3rd, 2006 10:42 AM
NAS D90 300tdi exhaust? Chris Cox Defender Technical Discussions 19 June 13th, 2006 04:59 PM
Pinging under full throttle... Doug Defender Technical Discussions 10 November 29th, 2005 11:02 AM
» Defender Registry
# 1275
bcoffeya
130
kellymoe
Add your Defender
