300TDI serpentine belt tensioner bearing R&R - Defender Source
Old August 31st, 2011, 07:04 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Has anyone replaced the bearing in their serpentine belt tensioner on a 300tdi ? Looking at the "nut" on the front, there are arrows indicating counter clockwise, but this is also the direction to turn it to remove tension on the belt for removal. I put quite-a-bit of pressure on it in both directions, but stopped as to not break something. Any experience out there?
Old August 31st, 2011, 08:29 PM
pendy's Avatar
pendy
jim pendleton
89'd90
The nut that holds it to the front cover is normal thread. The bolt that holds the bearing to the arm is backwards thread. I would break the bolt loose first. Then take off the nut to get the arm off if you deem necessary.
legend in my own mind
Old August 31st, 2011, 09:09 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Thanks Jim, that did the trick. Took longer to get the snap ring out than anything else.
FYI, Napa Part # for the bearing is 6203-2RSJ
Old August 31st, 2011, 09:15 PM
pendy's Avatar
pendy
jim pendleton
89'd90
I buy a sealed bearing and pull off the seals add extra grease, before assembly. Both sides, seems to add life.
300tdi, tdi
300TDI Timing Belt Tensioner Viton For Sale - Parts 1 September 2nd, 2011 10:31 AM
300tdi timing belt tensioner Viton Defender Technical Discussions 4 August 14th, 2011 10:03 AM
Freelander Timing belt Tensioner mjekogian For Sale - Parts 0 August 11th, 2010 12:44 PM
300 Tdi Serpentine belt failure roverboy Defender Technical Discussions 5 May 25th, 2006 02:53 PM
Bando D90 97 Serpentine Belt wea For Sale - Parts 7 December 24th, 2005 04:08 PM
