300TDI Serpentine belt tensioner bearing? - Defender Source
Old September 23rd, 2017, 12:22 PM
terryjm1's Avatar
terryjm1
Terry
1988 Land Rover Santana & 98 D1 TDI
Can anyone confirm the correct bearing for the main serpentine belt tensioner is an SKF 6203-2RSH? (*Not the AC belt tensioner)
Terry
Old September 23rd, 2017, 12:34 PM
Naplm00
Matthew
Any 6203 will work the 2rs denotes two rubber seals .
Any brand will work as well...you can pop off one of the rubber seals and pack it with more grease then reinstall it.
https://www.amazon.com/gp/aw/d/B0045...HpL&ref=plSrch
Old September 23rd, 2017, 08:32 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Here's the NAPA part number for the bearing only. 6203-2RSJ
When you get the snap ring out, that holds the bearing in, be sure to grind a notch in the end so next time removal will be easier
Old September 28th, 2017, 02:18 PM
DesertRat
Bryan Barnes
95 D90 2.8TGV
2x on the NAPA 6203-2RSJ. Worked for me in Moab a few years ago.
300tdi, tdi
300tdi belt tensioner came off! Mtanzania Defender Technical Discussions 8 September 22nd, 2013 09:41 PM
2.8 tgv serpentine belt tensioner DesertRat Series Technical Discussions 5 September 22nd, 2011 06:03 PM
300TDI Timing Belt Tensioner Viton For Sale - Parts 1 September 2nd, 2011 09:31 AM
300TDI serpentine belt tensioner bearing R&R Viton Defender Technical Discussions 3 August 31st, 2011 08:15 PM
Bando D90 97 Serpentine Belt wea For Sale - Parts 7 December 24th, 2005 03:08 PM
