300tdi remote oil cooler? - Defender Source
Old November 26th, 2008, 09:19 AM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Hello from Down South (not george)
While driving in Bolivia a few weeks ago the little o-ring that holds the hard line which brings engine oil to the cooler disintigrated and caused us to loose all our oil. Not good but I noticed the pressure falling ands saved the motor.
We bypassed the cooler and during the time we ran with no cooler the water temperature up long grades was significantly lower (we are quite heavy, it is hot and at about 4000m). We are now considering a remote engine oil cooler.
Are there any potential problems we should consider?
Is there an out of the box option?
Is some type of thermostat required?
Thanks in advance
Old November 26th, 2008, 08:42 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
where is the OEM oil cooler on the 300 Tdi now??
Old November 26th, 2008, 09:18 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Built into the radiator.
Old November 26th, 2008, 10:37 PM
Ah, the reason the water temp was lower was because the oil temp was higher!
Old November 30th, 2008, 03:05 PM
D90user's Avatar
D90user
steve
Yep, thats what I'd like to fix.
I don't think it is a problem unless running in the heat and heavy.
Any suggestions?
Old December 1st, 2008, 07:34 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
yup, plumb in an oil cooler. Done that several times with 300's. You can have the lines made at hydraulic shop to fit whatever cooler will work for you're aplication. I do this as generally when building bigger, better radiators I eliminate the oil cooler in the rad.
Matt Browne
Old December 1st, 2008, 10:31 AM
Steve,
I've been following your blog and your posts (internet access ?) are few and far between and pictures don't get me started....
Hook a brother up.
How does the 300 pull @ 16000 feet ?
Old December 1st, 2008, 04:30 PM
D90user's Avatar
D90user
steve
Matt- Thanks, that is what I needed.
Doug- Thanks for keeping up! Internet access has been spotty but the speed is prohibitively slow for uploading... But don't you fret I have been writing tonnes of useless banter and taking many pictures...some of beat up rovers in argentina.
300tdi, remote, tdi
Defender Oil Cooler Status Poll: Please Read. Hans Misc. Chit-Chat 4 March 12th, 2006 10:49 PM
Oil cooler hoses rvrsrvc For Sale - Parts 116 October 16th, 2005 05:47 PM
FOR SALE - Set of Used Oil Cooler hoses / window studs eric_besore For Sale - Parts 10 August 31st, 2005 02:18 AM
External Oil Cooler jabber Defender Technical Discussions 3 August 21st, 2005 04:45 AM
