300Tdi Radiator question - Defender Source
Old May 5th, 2008, 07:45 AM
Lyman
Lyman Saltsman
1987 Rokon Ranger
I need a favor... does anyone have a 300Tdi radiator out of a rig or empty in a rig? If someone could remove the fill plug and shine a flashlight straight down to the divider plate between the 1st and 2nd passes i'd appreciate it.
What i need to know is if there is supposed to be a 5/8 to 3/4" perfectly round hole in the plate, or if it's supposed to have a plug in it...
Lyman
Old May 5th, 2008, 05:13 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Call me remind me and I will look..
303-506-9429
Keith
Big, Red and ... aaa Red..
Old May 6th, 2008, 05:52 AM
Lyman
Lyman Saltsman
1987 Rokon Ranger
thanks Keith. hard to believe there is supposed to be a bypass within the radiator. ultrasound and rodding should get me back to normal.
Old May 6th, 2008, 11:23 AM
pendy's Avatar
pendy
jim pendleton
89'd90
There is supposed to be a bypass. It is common for me to have them blanked off when recoring a radiator. You can make a washer on a rod that will sit on top of the bypass as well if you are wanting to shut the bypass off. I agree it was a bad design.
JP
legend in my own mind
Old May 10th, 2008, 06:08 PM
Lyman
Lyman Saltsman
1987 Rokon Ranger
after a boil out and flush, the radiator shop found 18 tubes still plugged upon removing an end tank.
they rodded it and put it back together. i'm happy to say that Ol'Blue's temperature doesn't wiaver past 2 needle widths below 1/2 range no matter how hard i flog him.
i didn't have them plug the hole, as i never had a problem before and i didn't want to add another variable to the mix.
thanks for your replies guys, i appreciate it.
if you ever get out to northern NY, check us out at www.rok-freekz.com
300tdi, radiator, tdi
NAS D90 300tdi exhaust? Chris Cox Defender Technical Discussions 19 June 13th, 2006 04:59 PM
300Tdi wings/ radiator finisher (defender) Lyman Wanted 2 March 8th, 2006 05:51 AM
1995 Discovery 300TDI, Trail Ready.... Joe B For Sale - Vehicles 1 June 23rd, 2004 06:26 PM
300tdi Wiring Diagram? JimC Defender Technical Discussions 20 April 7th, 2004 09:39 AM
