300tdi R380 into 110 with 3.5V8 LT85 - Defender Source
Old May 19th, 2010, 02:05 PM
bitz's Avatar
bitz
Jon
NAS D90, 85 D110 CSW, 66 Dormobile
I'm getting my 300tdi next week and need some pointers. I've searched the board but I'm not coming up with all of the info that I think I'll need. I know I'll need to change the motor mounts, what about:
*Transmission Mounts?
*Drive Shafts?
*Transmission Tunnel?
Any advice or links to projects on the board would be greatly appreciated.
Thanks!
Old May 19th, 2010, 02:24 PM
You're gonna need a fair bit. Just off the cuff:
tdi crossmember (the trans/t-case mount to it)
correct r380, perhaps lt230
driveshafts
radiator
and stuff...
Old May 19th, 2010, 02:28 PM
I have a NEW 300tdi crossmember with mounts and such.
Ron
Old May 19th, 2010, 02:44 PM
defender 300 tdi r380 with bell housing-make sure you get the defender shifter tower/includes tcase shifter, radiator intercooler box, fan shroud, rear drive shaft, crossmember and mount, engine frame mounts (weld in), maybe front drive shaft (haven't compared the lt85's with lt77 and r380 fronts), r380 fiberglass tunnel cover, r380 floors, and seat box and bulkhead flanges to make the tunnel cover mate up. A ton of work but worth it in my opinion.
Old May 19th, 2010, 03:00 PM
bitz's Avatar
bitz
Jon
I'm not sure all that is included at this point but it seems like a pretty complete kit here are a couple of pictures.
ID:	27760   Click image for larger version
Old May 19th, 2010, 03:04 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Fling me your email on a PM...i've got some pictures and very accurate dimensions for where the engine mounts need to be welded.
The R380 sits on a bolt in crossmember, as said above. You can get all of the bits needed on ebay.
Old May 19th, 2010, 03:12 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Dude so jealous. One day I'll have a diesel.
MUDSUX
Old May 19th, 2010, 04:33 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
The 300 is nice and easy to install. you'll find that the LT85 propshafts are the same length as 300Tdi too.
Engine can be run on one wire (the fuel pump solenoid) and the whole engine only needs 4 wires to fully work properly (oil pressure, water temp, alt warn light and FIP solenoid.... 2 larger cables to starter and alternator charge also)
The glowplug plug in looms can be found here. The looms in that link are for a 200Tdi, but 200's use the same rubberised bullet connections as the earlier rovers (i.e. V8's with LT85 euro spec) so should all plug in correctly.
Old May 19th, 2010, 10:55 PM
bitz's Avatar
bitz
Jon
Here is a nice conversion I just found done by ECR. http://www.eastcoastrover.com/83.html They sure do nice work.
------ Follow up post added May 19th, 2010 11:09 PM ------
Ron
Ron,
Can you PM me a price.
Old May 20th, 2010, 07:14 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
I've got a full pile of 300tdi parts if you need anything else, and I'm not far away.
Matt Browne
Old May 20th, 2010, 09:37 AM
bitz's Avatar
bitz
Jon
Great I should know more on tuesday or wednesday
Old July 6th, 2010, 02:22 PM
bitz's Avatar
bitz
Jon
So the kit is pretty complete. Rad/Intercooler, motor and transmission mounts, fuel filter, relays, hoses, yada yada. Looks like right now the only things I need are the transmission crossmember and the motor mounts (the part that get's welded to the frame). The engine and transmission only have 60K on them but I'll probably do the clutch disk, throw out bearing, timing belt? Anything else I should do before space is tight?
Old July 6th, 2010, 02:30 PM
tweak
Darich Runyan
'04 Disco
Not to hijack the thread but it did bring up a couple of questions that I have had. Is the wiring harness for the v8 compatible with the tdi? Will the instrument cluster work or does that have to be changed out as well?
Old July 6th, 2010, 02:44 PM
bitz's Avatar
bitz
Jon
Ahhh good question. Was wondering that myself... Temp sensor, Oil pressure switch, etc....
Old July 6th, 2010, 02:54 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
What are you doing with the LT85?
MUDSUX
Old July 6th, 2010, 02:57 PM
bitz's Avatar
bitz
Jon
Hadn't thought about it yet but I'll probably be getting rid of it.
Old July 6th, 2010, 08:49 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
DO THE TIMING BELT! If it is an older motor you may want to get the timing belt modification kit. They upgraded the lower sprocket and the tensioner pulley. If it has the newer stuff the lower sprocket has ridges/walls on the outside to keep the belt in line. The older engines had this set up on the tensioner pulley. If the motor has 60K on it it is due for a belt replacement at any rate.
The wiring harness's have different part numbers for the diesel as compared to the gas motors. You might just be able too get the engine harness or do a cut and splice?
Land Rover 110
Old July 6th, 2010, 09:04 PM
Turbofan's Avatar
Turbofan
Ethan
'73 SIII/ D90 Hybrid
Bitz, Where are you doing the swap? I'd like to take a gander at this..
Old July 6th, 2010, 09:16 PM
I think you need these.
Ron
Name:	crossmember 300tdi small.jpg
Old July 7th, 2010, 10:53 AM
bitz's Avatar
bitz
Jon
Ron,
I have the two mounts I just need the crossmember and the mounts that get welded to the frame.
------ Follow up post added July 7th, 2010 10:54 AM ------
In my driveway. Just pulled the engine from the crate this weekend to size things up. Let me know next time your in town.
110, 300tdi, r380, tdi, v8
Build a 110? Chaucer Misc. Chit-Chat 36 March 19th, 2008 08:27 PM
300Tdi into an Ex-Mod 110 moose Defender Technical Discussions 5 May 27th, 2007 12:37 PM
