300tdi R380 into 110 with 3.5V8 LT85 - Page 2 - Defender Source
Old July 7th, 2010, 11:18 AM
Make an offer. What I PMed you was with the mounts which are spendy.
Old July 7th, 2010, 11:25 AM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
Originally Posted by bitz View Post
So the kit is pretty complete. Rad/Intercooler, motor and transmission mounts, fuel filter, relays, hoses, yada yada. Looks like right now the only things I need are the transmission crossmember and the motor mounts (the part that get's welded to the frame). The engine and transmission only have 60K on them but I'll probably do the clutch disk, throw out bearing, timing belt? Anything else I should do before space is tight?
I am glad you like the engine and the rest of the stuff that I sold to you. I called to see if you got everything in good order. Glad to see the engine is going to good use. I'll be sure to follow your build thread.
I thought mounts were in the bottom of the crate.
Old July 7th, 2010, 11:28 AM
He has the mounts, just not the crossmember.
Ron
Old July 7th, 2010, 01:09 PM
bitz's Avatar
bitz
Jon
NAS D90, 85 D110 CSW, 66 Dormobile
Thanks Clarence. There were a couple of things damaged but I'm not sure if it happened from the UK to you or from you to me. The oil pan is pretty much shot (Huge dent in the bottom) the alternator is pretty bent up too. Besides that everything looks great. And you are correct all of the motor and transmission mounts were in there.
110, 300tdi, r380, tdi, v8
Build a 110? Chaucer Misc. Chit-Chat 36 March 19th, 2008 08:27 PM
300Tdi into an Ex-Mod 110 moose Defender Technical Discussions 5 May 27th, 2007 12:37 PM
