300tdi pre-heat - Defender Source
Old February 27th, 2012, 08:24 PM
pabrit
Steve Hoare
1949 80"
300tdi pre-heat
Having the choice of a freeze plug block heater or lower radiator hose coolant heater which way would you recommend........or would fitting both be over kill?
Cheers
Old February 27th, 2012, 11:45 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Block heater is a better choice
legend in my own mind
Old February 28th, 2012, 01:11 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
I don't like the idea of cutting a hose and the having 2 additional points of fluid leakage. The lower hose type just seems hokey, like an after thought. Block heater is the way to go. Katz sells them for this engine. Search this forum for block heater for pat number.
Old February 28th, 2012, 04:38 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I've used the heater hose type and block heaters. Both work equally well. I prefer a block heater, they are a lot tidier.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old February 29th, 2012, 12:30 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Here's the thread.
http://www.defendersource.com/forum/...i+block+heater
Old March 1st, 2012, 10:26 AM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
I installed one of these (sealed around the edges with hi-temp silicone). On colder days it seems to idle smoother in less time. Who knows if its just me. Then again, I'm just in philly, not the great white north.
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old March 5th, 2012, 08:26 PM
pabrit
Steve Hoare
1949 80"
Thank you, Gents.
300tdi, tdi
Excessive heat in driver side foot well Chris Vitale Defender Technical Discussions 14 August 23rd, 2008 01:03 AM
NAS D90 300tdi exhaust? Chris Cox Defender Technical Discussions 19 June 13th, 2006 04:59 PM
Heat question Campbell Defender Technical Discussions 8 January 3rd, 2005 08:58 PM
1995 Discovery 300TDI, Trail Ready.... Joe B For Sale - Vehicles 1 June 23rd, 2004 06:26 PM
