300tdi plunger lift - Defender Source
Old December 14th, 2012, 10:57 PM
Turbofan's Avatar
Turbofan
Ethan
'73 SIII/ D90 Hybrid
300tdi plunger lift
Does anyone know what injection pump plunger lift at TDC should be? I've got a sick 300tdi at work that, at risk of sounding un-PC, seems to be a bit retarded. I couldn't find a value in Rave,and thought maybe someone might know. Thanks a lot!
Old December 14th, 2012, 11:26 PM
Whiesel's Avatar
Whiesel
Eric Williamson
LR-90 300 tdi
1.54mm. Though some say 1.6 is the hot-spot.
Eric.
Old December 15th, 2012, 12:41 AM
Turbofan's Avatar
Turbofan
Ethan
Thanks so much!
Old December 15th, 2012, 04:07 PM
Naplm00
Matthew
how exactly does 1 measure this plunger lift?
Old December 15th, 2012, 04:28 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
On the back of the IP, in the center of the fuel line outlets, is a plug. Remove it. Inside is the plunger, it rises & falls as the IP turns over sending fuel to each fuel line. To measure this rise and fall requires a screw in adapter & a dial gauge. To adjust the rise & fall requires the front gear/pulley to be adjusted and slightly turned clockwise or counter with the pin to gear (tool) inserted to maintain timing.
If I got any of this wrong please chime in to correct me.
Here's some more info.
http://www.dividingcreekimports.com/...umpTuning.html
Though this is a VW site the Bosch IP is basically the same
http://vincewaldon.com/index.php?opt...d=24&Itemid=28
Here's a thread from our forum
http://www.defendersource.com/forum/...ad.php?t=36001
And from the land of OZ
http://www.aulro.com/afvb/technical-...-timing-2.html
Couple more
http://www.cs.rochester.edu/~jag/vw/...i/injpump.html
http://ww2.justanswer.com/uploads/Cl...imingMARKS.pdf
Old December 15th, 2012, 05:00 PM
No you do not loosen the pump. The adjustment is the same way as normal with the adjustable pulley in the timing case.
You turn the engine until just shy of TDC. The dial gauge will not move for a bit. This is where the plunger is at its bottom. Zero the gauge. Continue turning until the engine is at TDC (by the notch on the ring gear). Note the dial gauge reading and that is the lift.
300tdi, tdi
NAS D90 300tdi exhaust? Chris Cox Defender Technical Discussions 19 June 13th, 2006 04:59 PM
300Tdi Fuel Lift Pump Lyman Defender Technical Discussions 2 May 23rd, 2006 05:53 AM
Tires sizes per lift ratio ini88 Defender Technical Discussions 9 December 22nd, 2005 01:02 AM
Inexpensive, minor lift ideas sought.. LRNAD90 Defender Technical Discussions 1 September 16th, 2004 06:59 PM
