300tdi p gasket naked or smear of silicone? - Defender Source
Old November 15th, 2012, 07:54 AM
Broncoduecer's Avatar
Broncoduecer
peter
D90
Hi everyone,
So when I was taking out the temp sender to install a VDO sender the stock sensor broke off. So I had to remove the thermostat housing and water pump. I recall putting a smear of silicone on the gaskets of fords, but don't know if that still holds true for Rovers.
Anyone have a preference? I'm leaning towards nothing, but a lit smear wouldn't hurt I suppose. The p gasket I got is the updated metal rubber one. The thermostat housing is your regular paper type.
Pete
Old November 15th, 2012, 08:12 AM
Never use silicone for anything. Hate that schmidt. OK check that, it has one good use and this is the only one, which is to seal the corners of V8 intake manifolds. Otherwise it is the devil's spawn.
If you must smear something use hylomar on both sides of the paper gasket. Overkill, but what the heck.
Old November 15th, 2012, 09:27 AM
I don't share Bill's disdain for silicone, more so just the sight of gobs of it gooping out of every seam. I try to wipe off any excess and don't use too much because it wastes product and does tend to clog passages and so forth when pieces fall of inside an assembly.
That said, I used Hylomar for my P-gasket. Since it doesn't cure I think it is a little more tolerant of creep and differential expansion and contraction that cause these things to leak.
Putting it on dry is asking for trouble IMO
Old November 15th, 2012, 11:47 AM
Broncoduecer
peter
D90
What type of Hylomar are people getting? Is it the same as the super black permatex product?
Old November 15th, 2012, 11:49 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Old school here, my Dad taught me just to smear grease on both sides.
Old November 15th, 2012, 12:47 PM
Broncoduecer
peter
D90
I read that alot on the uk forums. That also makes sense to me. Any leaks Dennis? Have you done your p gaspet or water pump?
Old November 15th, 2012, 12:54 PM
I've got a p gasket hanging in the garage and the old one started dripping, so this gasket is on my short suspense to do list. I'd love to hear a verdict on the grease. I was planning on doubling down both sides with hylomar as I hate dealing with cooling leaks, but hate how much work it is to get that crap off again on the next change out.
Mark Kellgren
KM4BOR
Old November 15th, 2012, 01:39 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
I haven't replaced the "P" gasket but I did replace the noisy water-pump, and I used grease there....no leaks. On old standard T-stat housings (ours uses a rubber seal on the 300Tdi's), I never had a problem using grease on those paper gaskets.
Old November 15th, 2012, 10:07 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
I used spray Hylomar on mine, never had a problem with it.
Old November 16th, 2012, 10:08 AM
Broncoduecer
peter
D90
The things they think of nowadays, I see someone in rapid city sells it on eBay.
Old November 16th, 2012, 11:15 AM
300tdi convert
Michael Giddinge
Late 80s 110 300tdi
Specific to the P gasket, I've had to replace mine twice in this engine. What I found after taking it apart the second time was that the raised groove in the metal gasket ended up not falling between the metal faces it was intended to seal, but on the edge of the water opening/path. My reaction was to just make sure that the new one aligned/sealed appropriately, but what I found was that I needed to take a hole file to one of the bolt holes in the gasket so it would shift slightly and better align the gasket. Seals fine now. Don't recall if it was sh*t part or not. This is the fourth time I've been involved in changing out a 300TDi P gasket, and first time I've run across it. Anyway, curious if anyone else has had a similar experience, and perhaps something to watch out for. May have just been a bad gasket, but two? That said, we often place large orders including multiple gasket sets, so may have been a pair in a bad batch. No idea.
Old November 20th, 2012, 12:03 AM
tdi-rick's Avatar
tdi-rick
Rick
'98 130CC
Bloody good observation.
Metal P gasket leaks are the bane of my existence.
I have one that is coming apart over the next few weeks that is leaking as the timing belt is (over) due, so I'll check the alignment.
Cheers.
Old December 9th, 2012, 08:19 PM
replaced mine today. It's a 2 beer job. took 2 hours to get the casing off from start.
ID:	62476   Click image for larger version
Mark Kellgren
KM4BOR
Old December 9th, 2012, 09:57 PM
Nice job. In response to the OP I smeared mine with Hylamar, and that was 2 years ago hasn't leaked a drop since...
Old December 9th, 2012, 11:41 PM
Yeah, I used blue RTV on both sides. Not taking any chances.
Mark Kellgren
KM4BOR
Old December 10th, 2012, 06:29 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
I've replaced about 25 or more I'd guess and smear grease on the gasket and have yet to hear of one leaking. I think the first one was over 10yrs ago.
Not a big fan of silicone.......see plenty of silicone abuse and failure. It has it's uses I'd suppose, but not in my shop unless it is a specific product that is manufacturer recommended.
Matt Browne
Old December 10th, 2012, 09:08 AM
when I do use rtv I use the clear. I can't like the blue red or black when they can be seen- a sign you have used too much.
Old December 10th, 2012, 09:11 AM
I just used a very thin coat on both mating surfaces just enough to hold the gasket in place. I've misplaced my hylomar
Mark Kellgren
KM4BOR
Old December 11th, 2012, 06:37 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
One thing I have noted is that joints sealed with silicone will come apart fairly easily and cleaning the gasket off is not at all difficult (probably due to the leaking). Greased gaskets (oddly) seem to stick to aluminum with surprising tenacity and require a bit more grunt to disassemble and clean. This applies to parts that have been together for a while.
Matt Browne
Old December 11th, 2012, 07:39 AM
What about Hylomar, which is not silicone based?
300tdi, gas, tdi
300TDI silicone intercooler hoses brn24whl The Vendors Loft 42 January 30th, 2012 09:01 AM
manifold gasket 300tdi Ren Ching Defender Technical Discussions 14 February 4th, 2011 06:53 PM
water pump gasket kolvedic Defender Technical Discussions 2 September 11th, 2005 08:22 PM
