300Tdi Oil Leak - Defender Source
Old August 3rd, 2016, 02:25 AM
RBBailey
RBBailey
1965 IIa
300Tdi Oil Leak
Under load, I'm loosing enough oil from the filter area that I won't be able to drive more than a few miles before it runs dry. I can't tell if it is coming from the filter gasket itself, or the mounting area since it is smart and is coming from behind the filter and junk so as not to be seen.
Project:
1965 IIa SWB
Old August 3rd, 2016, 07:03 AM
speedpin's Avatar
speedpin
Looking ;)
I had some issues on my 200tdi after a filter change. Come to find out the old filter rubber gasket had come off and remained on filter housing not letting new filter seal correctly.
~ Semper Fidelis ~
Old August 3rd, 2016, 08:27 AM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Check the oil cooler lines and connections. I had an oil cooler line that was leaking at the connection between the rubber and metal parts and a lot of the oil was making its way back to the filter area before dropping off.
Old August 3rd, 2016, 11:05 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Could be the pressure sending unit is leaking at the plastic & metal interface crimp.
Old August 3rd, 2016, 11:22 AM
RBBailey
RBBailey
1965 IIa
Thanks for the input, I'll see about finding where this is coming from once I've had my coffee.
This makes me wonder. Is there anything specific I need to know about changing oil in the 300Tdi? Steps to know? What not to do?
Project:
1965 IIa SWB
Old August 3rd, 2016, 11:55 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Be sure the old oil filter rubber doesn't get stuck to housing.
I use an old 1 gal. plastic milk jug with the top cut off to let the oil leak into & catch the used filter.
300tdi, tdi
Dipstick oil leak 300tdi aosias Defender Technical Discussions 6 April 1st, 2014 10:54 AM
Oil Leak..Oil Pressure Switch Failure? tebby Defender Technical Discussions 2 December 19th, 2010 03:16 PM
300tdi oil leak, main journal? Shane@EVS Defender Technical Discussions 9 May 8th, 2007 06:58 AM
300Tdi oil leak? Gkase Defender Technical Discussions 8 July 24th, 2006 12:13 PM
