300Tdi Oil Cooler Lines - Defender Source
Old February 1st, 2012, 09:16 PM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
I think I've identified the leak (or at least one of them). The oil cooler lines (in particular the fitting ends that connect above the oil filter) look suspect. Given the age of this engine it can't hurt to replace them even if that is not the source of the leak.
Has anyone bought these stateside? if so, where and how much.
I'm not even going to wast my time with RN, I'm sure they will be a "special order" item and we all know that is code for "bend over".
Old February 1st, 2012, 09:40 PM
the rover shop
shayne young
I take them to a hydraulic hose maker and they put in fittings with a better quality hose and its much cheaper and much more betterer...and then you just replace the line sections...I think there is some pics in my build thread section..
300tdi, tdi
oil cooler lines CHRIS C Defender Technical Discussions 39 December 21st, 2004 11:30 PM
Oil cooler lines revisited rover4x4 Defender Technical Discussions 5 July 9th, 2004 08:40 AM
Stainless Oil cooler lines??? Neo Defender Technical Discussions 3 February 3rd, 2004 08:04 PM
