300Tdi Oil Change Process - Defender Source
Old August 21st, 2006, 11:04 PM
ronward's Avatar
ronward
Redsrover
None - sadly
Changing oil in the 300 Tdi. Is the procedure the same as Rover V8s? That is, do I drain sump until empty, refit the drain plug then fill with Rotella 15w40, then remove the old filter, fill new filter with new oil and refit, then start engine and let it run a minute and shut down and check level? Or do I change the filter before filling engine with fresh oil?
Thanks!
Anything is possible, with the right tools...
Old August 21st, 2006, 11:57 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
The 300 TDi is a little different. Because it is Euro-spec, things are done in metric. So you have to reverse the process. Fill the engine up with new oil, then change the filter. Lastly, pull the drain plug and let all the oil drain out. And your done!
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old August 22nd, 2006, 01:26 AM
Fortunately, when you surround your defender in a full-body cage, the engine feels safe and cozy - free from harm. In this nurturing environment the engine will run with no oil.
If you dont have such a cage, you might do what I do, which is drain the oil, remove old filter, fill and attach new filter, replace plug and fill remainder with oil.
Old August 22nd, 2006, 06:39 AM
ronward's Avatar
ronward
Redsrover
None - sadly
Thanks Jim!
Old August 27th, 2006, 05:07 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Jim's method is the one I'd go for too.
Buck's method saves on oil but you'd get through engines at a phenominal rate
Mike Hammond
Old August 27th, 2006, 11:16 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
dont forget to then clean up all the oil that pours down your diff and makes a huge mess every time.. That damn filter is in such a shitty spot.
Legend in My Own Mind.
Old August 27th, 2006, 12:19 PM
Oh thats right, I love that. I usually put some rags on the diffto absorb and deflect the mess.
Old August 27th, 2006, 03:59 PM
mikeslandrover
Mike Hammond
I wrap the whole filter in a large plastic bag
Mike Hammond
300tdi, tdi
Oil Change gtg067i Defender Technical Discussions 31 July 13th, 2005 10:24 AM
Sick Of Messy Oil Change javelinadave Defender Technical Discussions 17 October 12th, 2004 09:28 PM
Oil Change Screw-up zed111 Defender Technical Discussions 9 July 19th, 2004 11:48 PM
