300Tdi oil advice needed... - Defender Source
Old July 16th, 2006, 01:20 PM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
My 300Tdi came with 10w 40 from England...after buttoning everything up and running it for a bit I am about 1/2 to 1 qt low...I can't find any diesel labeled oil in 10w 40 at the local auto stores...just 15w 40...
the 10w 40 they do have isn't labeled petrol or diesel...should I use a quart of the 15w 40 or a quart of the 10w 40???
thanks
George
Old July 16th, 2006, 01:46 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Use the 10w40 to top it off. Then at naxt oil change, go to the 15w40 and run that from now on. Nice to see you have it running already!
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old July 16th, 2006, 05:21 PM
You can mix grades with no issues whatosoever, especially in such a small quantity.
I use Mobil1 SUV formula, which is rated for diesel engines, but I think I'm switching to reline HD next time because the Mobil1 SUV stuff is hard to track down.
Old July 16th, 2006, 07:20 PM
Gkase's Avatar
Gkase
George Kase
Thanks guys...topped it off with 10w 40 and am looking at Shell Rotella T 15w 40 for its regular diet...
yes...it's running and it's great...i'll write a more in depth driving impressions post on chit chat in a day or so...
plus all the thanks I owe to virtually everyone on the list...but we'll get to that more officially in a bit...
George
Old July 16th, 2006, 09:04 PM
we use rotella in all of our diesals
Old July 16th, 2006, 09:44 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
If you really want to do the research you can go to the website of the Society of Automotive Engineers at www.sae.org and look up the various oil ratings - I think the latest diesel oils are "SG" rated.
I just run Shell Rotella T 15W-40W in all my cars - it keeps the insides of the engines very clean and is available at Walmart or Sams Club. Works great in Porsches and my diesel Rovers (SIIA and Tdi) both run the stuff.
Old July 17th, 2006, 04:32 PM
Gkase's Avatar
Gkase
George Kase
just curious, do you use Rotella T synthetic or non synthetic?
Old July 17th, 2006, 09:45 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
I use the non-synthetic since I religously change my oil every 3300 miles. Synthetic is too expensive unless you extend your oil change intervals and I'd rather have clean oil in the engine more frequently.
Old July 18th, 2006, 01:27 AM
Yeah, the old dino more regularly or synthetic with extended life question. There is too much opinion intertwined to reach a conclusion - so for my part, I think using more than a gallon of oil every 3k miles is wasteful, so I'd rather have synthetic and send less of it out with the recycling.
Old July 18th, 2006, 07:07 AM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
Remember that diesels put a lot of particulate contamination into their oil - thats why it turns so black so quickly - and the true diesel oils like Rotella hold those particles in suspension instead of allowing it to build up on the interior surfaces of the engine. This high detergent factor of Rotella is what also makes it attractive for use in air/oil cooled engines such as Porsches - clean engine interior = better heat transfer. I'm balancing it all out by returning the waste oil to the local NAPA for recycling and running Biodiesel as my primary fuel.
Old July 18th, 2006, 07:22 AM
Gkase's Avatar
Gkase
George Kase
It seems for those of us in northern climates (-30F) that Rotella T synth 5w 40 is the way to go to ensure turbo health?
Old July 22nd, 2006, 03:31 AM
smenzel's Avatar
smenzel
Sandro
1967 Series IIA
I've heard good things about the Shell Rotella oil(s) but, on recommendation of my mechanic, went with Chevron Dello in my 2.5L diesel.
300tdi, tdi
quick help needed 4.2 oil lines Abrooks Defender Technical Discussions 8 February 10th, 2006 02:38 PM
Replacing Alt, H20 pump, fan clutch, and belts - Advice needed arbik Defender Technical Discussions 3 January 7th, 2006 09:11 AM
Oil leak rustydefender Defender Technical Discussions 19 December 9th, 2004 09:06 PM
