300tdi No Fuel - Fuel Cutoff Solenoid - Defender Source
Old April 12th, 2011, 11:24 AM
Epsom_D2
Sean-Paul Ferrera
1994 D90 POE
So my 300 isn't getting any fuel and I was wondering if anyone knew if there was a part number for the fuel cutoff solenoid (Rover Part #RTC6702) that I may be able to cross reference to a US parts catalog that the local auto parts store may have.
Thanks in advance,
S-P
Old April 12th, 2011, 02:18 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Easy way to tell.... remove the spade connector/wire from it.
unscrew the solenoid (you may need to get the correct size spanner and grind the outer edges of it off so that it can fit in there) then remove the piston/plunger thing and the spring.
Refit it, and you should have permanent fuel supply. You'll have to stall it to stop the engine (or if its an auto, block off the air intake, but not with a rag! a mate of mine did this on a toyota hilux, and it sucked the rag in... as he had the air filter off at the time, the rag went straight up the inlet manifold and into the engine.... took him ages getting the head off and removing all the bits of rag!)
Old April 12th, 2011, 03:40 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
With the ignition on you should hear the stop solenoid click as you apply/remove 12 volts to it. That way you can tell if the stop solenoid is good.
Mike Hammond
Old April 19th, 2011, 10:22 PM
Epsom_D2
Sean-Paul Ferrera
1994 D90 POE
Thanks guys. Turns out that I'm not getting sufficient voltage to the solenoid, I'm getting like .25 V. In my mind this is more likely just the meter reading error than anything real. I haven't been able to determine where the power wire is coming from as it goes into a larger wire loom which I have tried to follow, but keep losing as it goes behind the engine. I think it connects to the starter, but I cannot say for certain. I'd be grateful to anyone who can provide me with an idea where I should hunt for lead and where it connects as it is driving me quite crazy that I cannot solve a one wire problem.
diesel_jim, thanks, I will be taking your advice until I can solve the problem correctly.
Thanks again.
Old April 20th, 2011, 05:11 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Sean-Paul, Defender circuit diagrams are always a bit of a crap shoot, but as best I can tell -- the fuel cut-off solenoid is connected by a white wire that goes to a plug connector in the engine compartment near the bulkhead. It appears to be fed by a white/black wire direct from the ignition. Hard to sort if the circuit includes a fuse, but if it does it will be in the interior fuse box, not the one in the engine compartment. There is no direct connection to the starter.
Check fuses first. Then trace from the solenoid to the connector and check to see if you have power that far. It could be as simple as a corroded pin in the plug.
Tony
1984 110 "Smokey" (sold)
Old April 20th, 2011, 05:47 AM
mikeslandrover
Mike Hammond
Less messy and brutal than stalling the motor would be to run a 12v feed from the battery via a switch to the solenoid. Two advantages, you can see if the solenoid works ( clicking sound when applying/removing power and if the solenoid is good the truck will run and you'll be able to stop it with the flick of a switch.
Mike Hammond
Old April 21st, 2011, 01:42 PM
Epsom_D2
Sean-Paul Ferrera
1994 D90 POE
Well as it turns out my multimeter had low batteries when I original checked the voltage. I do have a full 12 volts at the solenoid. That being the case, I have pinpointed the solenoid as the problem. Now I have one last question, what size wrench should I be using the remove it. It appears to be a 23mm, but before I go purchasing more tools (not that I really mind) I'd like to make sure to have the right size.
Thank again for all the help.
300tdi, fuel, tdi
Calling all diesel guys - Biodiesel??? cbass Defender Technical Discussions 47 January 31st, 2006 11:18 AM
300tdi diesel fueling control solenoid Chris Cox For Sale - Parts 1 January 2nd, 2005 07:22 PM
Looking for a 300TDI Fuel filter EdHsu Defender Technical Discussions 2 September 12th, 2004 01:11 PM
Fuel lines for NAS D90 with 300tdi? Chris Cox Defender Technical Discussions 3 December 5th, 2003 04:20 PM
