300Tdi locating coolant temp sensor? - Defender Source
Old March 11th, 2009, 06:06 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
I have a sensor in the middle of the top of the head that appears unused, but I dont see the coolant temp sensor location anywhere.
Old March 11th, 2009, 08:20 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Front of engine on passenger side near thermostat. Has a male electrical connection.
Old March 11th, 2009, 11:26 PM
discotdi
Todd Miller
Land Rover
I have that same sensor, I think, towards the back of the head looks like maybe a two prong type connector? Nothing is plugged into mine either. I also have a 300 tdi Disco.
Old March 13th, 2009, 02:25 PM
crown14's Avatar
crown14
Verticalscrote
Found it after following the wire. They really hid the little bastard.
Old March 13th, 2009, 09:57 PM
johan's Avatar
johan
johan
2009 Range Rover
the sensor in the head is only for engines with EGR. This was on all Land Rovers in countries with emission regislation. No problem if it is not connected, just the EGr doesn't work the engine will even run better.
Johan
Old March 15th, 2009, 05:46 PM
crown14's Avatar
crown14
Verticalscrote
Ah, I had a feeling that was the answer.
Old May 23rd, 2012, 08:38 PM
pabrit
Steve Hoare
1949 80"
Is this sensor a thermal switch (ie: on/off) or suitable for hooking up a secondary temperature gauge. If the later, what is the sensor resistance range. Any suggestions on suitable gauges?
Cheers
Steve H
Old February 22nd, 2017, 12:36 AM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
Cheers
Steve H
Ha, old thread, but I'd like to know this answer.
Old February 22nd, 2017, 09:32 AM
This it? ERR2081
ERR2081 | Temperature sensor in cylinder head - 300TDI - Paddock Spares
That is certainly a sender and not a switch. I'm not sure that helps anyone unless you have a programmable gauge and want to take the time to calibrate it. Knowing the thread size would be useful in sourcing a known sender. The interwebs say it is M12x1.5
Old February 22nd, 2017, 09:35 AM
Here are the specs for it, I believe....
http://www.bosch-motorsport.com/medi...2569739pdf.pdf
Old February 22nd, 2017, 05:10 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
So it seems that sensor is useless unless connected to something programmable - eg an ECU or some kind of eg raspberry pi homebuilt engine monitoring system.
300tdi, coolant, sensor, tdi
coolant temp sensor rover4x4 Defender Technical Discussions 1 August 9th, 2008 10:30 AM
Fuel Temp Sensor engine code Tim Scully Defender Technical Discussions 0 January 9th, 2008 08:34 PM
Erratic Oil and Temp Sensor Jon_Winningham Defender Technical Discussions 10 March 30th, 2007 09:27 PM
300tdi temp sender thread?? D90user Defender Technical Discussions 2 March 16th, 2007 03:11 AM
