300tdi lift pump pressure - Defender Source
Old November 27th, 2013, 01:54 PM
Surfin' Elvis
Chuck
95 RRC 300tdi/wvo conversion
I run a 2-tank diesel/WVO fuel system and have been through three Facet electric pumps in three years. While still a cheap way to go, considering I drive nearly for free, I have decided to upgrade my electric lift pump to a Walbro FRB-5.
It is rated for 8-11psi.
Is this too much pressure to send to the IP?
Also, since I loop my return fuel back to the IP when on WVO (to retain as much heat as possible in the WVO), at what pressure does the IP return fuel? I ask this because, since I am returning fuel from return port of the IP back to the inlet of the IP, I know the IP inlet can handle at least the return pressure from the IP.
Thanks in advance.
By the way, if anyone wants to know why I do not use the stock mechanical lift pump, my reason is that I am not certain the diaghram can handle the fatty acids in the WVO as I had a new one fail in less than 6 months. It was a pain to access. Roadside repairs are much easier when you only need to access the inner fenderwell rather than the lower back end of an engine block!
Old November 27th, 2013, 02:06 PM
The manual says the stock pump is 3 to 4 psi. The return line should loop back to the lift pump inlet, IMO, and not be under pressure.
Old November 27th, 2013, 02:53 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Originally Posted by Surfin' Elvis View Post
I run a 2-tank diesel/WVO fuel system and have been through three Facet electric pumps in three years... Roadside repairs are much easier when you only need to access the inner fenderwell rather than the lower back end of an engine block!
Chuck:
If you want to call I can answer all your questions.
RDavisinVA
300tdi, tdi
td5 fuel pump in a 300tdi Muscat Defender Technical Discussions 11 April 8th, 2010 10:35 AM
300Tdi Fuel Lift Pump Lyman Defender Technical Discussions 2 May 23rd, 2006 05:53 AM
