300TDI leak T-Seals or Rear Main? - Defender Source
Old October 15th, 2014, 07:30 AM
red64chevelle
Daniel Smith
86 110 300TDI,16 Disco Sport
So, I have just about everything sorted out. I have a pretty good leak of engine oil (about a drop a minute) from the flywheel housing. I rebuilt the engine prior to installation, so I might have screwed something up. Is there a way to determine if the "T-seals" or the rear main seal is the problem?
Otherwise, I will probably attack the T-seals first. From what I have read, I can replace them by removing the pan. The Rear Main will require me to drop the tranny.
Thanks in advance.
75% of all Land Rovers ever made are still on the road...
the other 25% at least made it home.
Old October 15th, 2014, 07:59 AM
There are some real garbage seals out there. Even those masquerading as "genuine". My money is on the rear main. You want the Dowty Teflon one. Those too are counterfeited ( who knows why )
Old October 15th, 2014, 08:01 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
In case you change the rear main seal, there is an upgraded version of that seal, it's twice the cost but it is supposed to be stronger. It's available at Turner Engineering.
Cheers
- Charles Eames
Old October 15th, 2014, 08:20 AM
red64chevelle
Daniel Smith
Do you know where to get a real one?
Old October 15th, 2014, 08:30 AM
Depends on who you like.
Google "LUF 100430" and pick your winner. For example:
http://www.rimmerbros.co.uk/Item--i-LUF100430
Old October 15th, 2014, 10:05 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
http://www.turnerengineering.co.uk/acatalog/300Tdi.html
- Charles Eames
Old October 15th, 2014, 10:11 AM
red64chevelle
Daniel Smith
I saw that one. The description didn't say anything about it being teflon. The Turner seal does seem to be what everyone recommends.
Any ideas about isolating whether the leak is from the t-seals or the rear main seal?
Old October 16th, 2014, 09:12 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
My bet is rear seal also. You can drop the trans or take out the engine, that would depend on you.
- Charles Eames
Old October 16th, 2014, 09:28 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Thanks in advance.
Did you do the rear main when you did the rebuild? Did you touch the seal with your fingers?
Old October 16th, 2014, 09:51 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Damned Ebola !
- Charles Eames
Old October 16th, 2014, 10:33 AM
red64chevelle
Daniel Smith
I didn't personally replace the rear main seal. I couldn't physically get to it while the engine was on the engine stand. I had a nice guy in CT pick up my 110 and drop it back off with the engine/tranny in-place and the 2.5 Petrol on a pallet. I forgot to give him the rear main seal that came with the gasket kit, but he said he picked one up and installed it.
I figure I will be buying one from Turner and dropping the tranny to replace it. The whole project will have to wait for a bit while I play Navy for a bit.
Any thoughts on the gasket that goes between the rear main and the block? Some say permatex it, some say gasket. Any experience either way?
Old October 16th, 2014, 11:35 AM
did you rebuild the engine without removing the crankshaft? I'm pretty sure the rear main seal bolts into the rear main bearing housing as well as the block.
you don't need to pull the oil pan to do the rear main seal.
If it's leaking that much and the t-seals were never disturbed then my money is on the seal itself.
Thanks in advance.
Old October 16th, 2014, 04:02 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Daniel,
I did the replacement this summer.
http://www.defendersource.com/forum/...0&postcount=46
But I didn't sealed the gap between block and flywheel housing!
It's leaking drop by drop.
Have to do the whole procedure one more time!
Needed parts:
Be sure the lip of the gasket shows towards the engine block!
Use bolts to center the gasket behind the seal.
Never touch the lip of the seal!
You just have one try to fit the seal onto the crankshaft with the inner helper installed. Don't remove it!
Don't lubricate it!
When done the inner plastic for will be ejected by the crankshaft. The lip then sits correct to it.
The T seals are available in rubber or kork.
Good luck
Kurt
Old October 16th, 2014, 06:45 PM
red64chevelle
Daniel Smith
Yes, I completely rebuilt it. Crank out, all bearings, rings, honed cylinders. I replaced the t-seal with the one that came with the gasket kit. I think it was a cork one. I am thinking the next one will be the rubber type.
Old October 16th, 2014, 06:55 PM
red64chevelle
Daniel Smith
Originally Posted by Arlo View Post
Daniel,
Good luck
Kurt
Kurt,
Thanks for all of your information. So, you would recommend the rubber t-seals? Did you put any RTV on them, or just install them dry?
Thanks again.
Old October 17th, 2014, 05:04 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
If oil is comming out of the drain hole, I would like to tip on the main oil seal.
The T seals need to get lubricated and special formed helper things screwed to the block so they will fit the narrow gap. The outstanding end of the seal at the bottom has to be cut with a surplus of 0,8mm to the surface of the block.
Old December 4th, 2017, 06:06 PM
NC_MULE
Pat
1991 Range Rover Classic w/300tdi
Ok I admit I touched it. The old main seal felt (which was leaking) like hard plastic not like any other oil seal I've handled. So I touched the new one and it's kinda hard and not like any seal I've handled before.
Soooo....do I really need to toss this new seal since I touched it?
The one I touched was a allmakes 4x4 made in India. I'm going to look up the Turner one but I hate to put the project on hold for a UK shipment.
Thanks pb
300tdi, seals, tdi
Cross Seals by rear main 97-D90-736 Defender Technical Discussions 64 June 15th, 2016 05:17 PM
TD5 bulkhead vent seals vs. NAS seals Tyler Wirken Defender Technical Discussions 11 March 14th, 2011 10:22 PM
300tdi oil leak, main journal? Shane@EVS Defender Technical Discussions 9 May 8th, 2007 06:58 AM
Replacing front and rear main seals TND90 Defender Technical Discussions 0 January 24th, 2007 01:10 AM
