300TDI installed - Defender Source
Old July 13th, 2010, 05:56 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
300TDI installed
So the motor is in! The RDS mounts worked great. I do notice the 300tdi is a bit angled in the engine bay upwards in the front - but after looking at a lot of other conversions this seems kinda normal, right? I couldn't have really gone much lower with the mounts on the frame rail.
I do wonder if the motor mounts I have are from a Discovery and not a D90 and maybe this is why it's higher in front? Installed it's lined up with the slightly lowered radiator (which now has about the overall same height as my old V8 unit at 17") and now I just need to figure out plumbing. Mostly no big deal, but I have a couple questions.
1) Will most any muffler shop have the flange to mate to my exhaust?
2) Will stock oil lines for a 300TDI work or do I need to get those fabricated?
3) The Denso aircon compressor (yup I like AC) has a funny flange on it to which the A/C lines are supposed to connect, which is completely different than what I had on the V8. See attached. Where do you find that thing?
ID:	29331   Click image for larger version
Old July 13th, 2010, 06:11 PM
You have the newer bolt on flange type a/c compressor. The lines are factory parts- should be able to get them readily. ECR is Elite's US agent so they may have them in stock. Can't think of a reason why stock oil lines wouldn't work. But if they are slightly different you can go to any Parker store with what you have and they can make up custom lines using your original ends.
300tdi, tdi
NAS D90 300tdi exhaust? Chris Cox Defender Technical Discussions 19 June 13th, 2006 04:59 PM
300Tdi wings/ radiator finisher (defender) Lyman Wanted 2 March 8th, 2006 05:51 AM
D110 300Tdi AC Compressor? Hssser Defender Technical Discussions 3 August 17th, 2005 07:47 PM
1995 Discovery 300TDI, Trail Ready.... Joe B For Sale - Vehicles 1 June 23rd, 2004 06:26 PM
