300tdi injector and VE pump servicing - Defender Source
Old January 15th, 2012, 03:37 PM
piper109
Steve
1999 Disco 1 SD w/300tdi
I have just had my 300tdi injectors serviced with new nozzles. I was pleasantly surprised by the improvements.
Engine is smoother, quieter and the biggest improvement I have seen is off turbo power. Low speed hills were a problem for me, especially my very steep driveway(Blue Ridge) but now car will accelerate cleanly and well from ~ 1500 rpm in second whereas before I had to slow down and select first gear. Hill climbing overall is significantly improved. Here in the NC mountains that is very important.
The injectors were serviced by a friend of mine in Maine. I sourced the nozzles on Ebay UK for about $145. They are genuine Bosch and Brazilian made. He installed them and checked the primary pressure. Checking and adjusting secondary pressure on these injectors is not easy as the shims are all staked in place but adjustments are rarely needed I understand.
It seems that these nozzles are not easy to find in USA and are pricey.
If you need work of this type done or need new seals in your VE injector pump, contact him as follows:
Tom Bryant
Wiscasset Maine
email: Thosbryant@gmail.com
He is meticulous comes highly recommended. He also services Volvo diesel injectors, IP's and SU carburetors.
I am all smiles. The servicing was very worthwhile doing.
Steve
Old January 15th, 2012, 05:54 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Divulge the new nozzle number.
Old January 15th, 2012, 08:05 PM
piper109
Steve
The number on the nozzle packaging is as follows:
0 433 175 061
DSLA 145 P 366
Steve
Old January 16th, 2012, 12:14 AM
Steve:
Very interested in getting a set serviced. How much did he charge to re-nozzle with supplied parts?
Also, what eBay seller did you purchase the nozzles from?
Old January 16th, 2012, 09:22 AM
piper109
Steve
Steve:
I bought my nozzles at "diesel-top-shop".
Tom is very reasonable but he should speak for himself so please email him to get a quote from him.
Steve
Old January 16th, 2012, 09:57 AM
Naplm00
Matthew
I bought the same nozzles and did the injector rebuild myself. We will see how it goes
Old January 20th, 2012, 08:35 AM
piper109
Steve
I thought about doing mine myself too. I opted to send them to Tom because he has lots of injector experience and some test equipment so it seemed to make sense.
Very pleased with the results.
Steve
Old January 20th, 2012, 09:03 AM
carlosz's Avatar
carlosz
Carlos
Steve:
Lav, all my heavy duty diesel stuff has gone locally to a shop in alexandria off general washington, and or another located in marlow heights (I will have to do more research on that as I know where it is located but cant remember the address)
if interested let me know, I can look deeper into it.
300tdi, tdi
