300tdi head gasket question - Defender Source
Old May 26th, 2015, 10:32 PM
USLandy's Avatar
USLandy
Andrew
defender 90
I've been looking around on the web for a while now and cant seem to understand where to locate the 1, 2, or 3, holes which represent the head gasket thickness. Anyone tell me how to find this so I can order the right head gasket and not all three... lol. I have the understanding that stripping the head and measuring is the best but this is my daily driver so I do not have the luxury of doing so.
Thanks in advance!
Old May 26th, 2015, 10:47 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
I always have the head skimmed so it is COMPLETELY flat, then would order the thickest possible from RDS.
RDavisinVA
Old May 26th, 2015, 10:52 PM
USLandy's Avatar
USLandy
Andrew
defender 90
I will be replacing head with the turner engineering performance one, figure I might as well upgrade. So if I have a new head I can fit the 0 (zero) hole one as it is the thickest??
thanks for the response!
Old May 26th, 2015, 10:54 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
That is what I commonly do.
Does Turned not supply the gasket set???
RDavisinVA
Old May 26th, 2015, 10:56 PM
USLandy's Avatar
USLandy
Andrew
defender 90
I think they do, but I was unsure of which thickness. Also, will be doing the water pump at the same time so I was ordering everything separately like a dummy.
Old May 26th, 2015, 11:52 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
The gasket thickness ain't like oversized pistons. It is not a question of new head or skimmed one. It is the measurement of the piston's head going out of the block. Well, at least that is my understanding of it. Having the thickess gasket is a safe bet but, will it last as long as the proper one for your engine will?
Old May 27th, 2015, 01:51 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Indicator is located just below and slightly back from the #3 glow plug opening - if not changing anything in the bottom-end you can use the same gasket size you are replacing (or measure for piston extension above the block and size appropriately)
Old May 27th, 2015, 05:05 AM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
The location is a little bit hidden by the airfilter bracket.
Old May 27th, 2015, 05:06 AM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Old May 31st, 2015, 06:52 AM
Ohlins's Avatar
Ohlins
Retired Weirdo
1986 Army 110
You'll see the head gasket tab exposed where stated.
The gasket will have 1,2 or 3 small holes existing. Turner's should supply the Elring make of gasket.
If it were I,I'd replace with what has been on it already. E.g. my 300tdi came out of the factory with a 3 hole gasket.
All the best
200tdi Ex British Army 110 Hardtop 139142kms
2.286 Petrol Series 3 Lightweight 75,043kms
3.2DiD Pajero 266,000kms
Yamaha XTZ660Z Ténéré 58112kms
Gas Gas 300EC Ohlins Enduro Moto.
Old May 31st, 2015, 09:22 AM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
There is a red circle where you will find the holes. This one appears to be a two hole.
Name:	Screen Shot 2015-05-31 at 6.13.23 AM.png
Old May 31st, 2015, 03:46 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
@Eagle eye Chris
Thanks for the red circle!
I wasn't able to do this job.
Old June 1st, 2015, 10:17 PM
USLandy's Avatar
USLandy
Andrew
defender 90
Thanks for the replies guys, sorry for the slow response... somehow I got pneumonia and have been sick as a dog so hadn't messed with defender. Last of the parts should be coming in this week and I'll be getting to work.
Old June 2nd, 2015, 01:57 AM
Ohlins's Avatar
Ohlins
Retired Weirdo
1986 Army 110
Gosh...not so good...it'll take a bit of time to get fully over that illness...the Deafener can wait eh?
All the best
300tdi, gas, tdi
200tdi Head gasket question discotdi Defender Technical Discussions 19 July 17th, 2017 12:08 PM
Head Gasket Kit? Quimbola Defender Technical Discussions 9 November 5th, 2004 11:24 PM
Anyone done their own head gasket? vesparover Defender Technical Discussions 16 October 9th, 2004 10:34 PM
d90 dead 4 hours from home! head gasket? vesparover Defender Technical Discussions 4 August 17th, 2004 04:47 PM
