300tdi glow plug light is staying on... - Defender Source
Old September 3rd, 2016, 08:42 PM
LI90
Jim
1986 90 xmod
Took the rover out today.. It started as always, and the light worked as usual.. Then while driving, it came back on - and now it will not go off.
Jim
Old September 3rd, 2016, 08:59 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Pull the plug off the relay or pull the relay out.
I have mine on a 5 Amp fuse in the interior fuse panel, that I only use when the ambient is in the 20F's. Some guys here say to use the cycle year round but, I've had no issues doing it this way in 15 years.
Old September 4th, 2016, 09:30 PM
atpick's Avatar
atpick
Andy
1990 110
Originally Posted by LI90 View Post
Took the rover out today.. It started as always, and the light worked as usual.. Then while driving, it came back on - and now it will not go off. Jim
I had this issue on my 200tdi. There was a short in the glow plug wiring that was causing it to stay on. Replaced all wiring and plugs, issue resolved.
300tdi, ht, tdi
Restoration: Staying Organized DailyDrivenDefende Defender Technical Discussions 26 January 2nd, 2016 01:37 PM
Glow Plug Light turn on when dome light is switch is flipped on Elbee Defender Technical Discussions 4 September 9th, 2014 05:27 PM
Continuing to obsess about staying cool... aaronlam Defender Technical Discussions 9 August 11th, 2012 01:25 PM
Rear brake calipers staying engaged. FlaD90 Defender Technical Discussions 4 April 12th, 2009 06:29 PM
LR Glow Plug relay temp? dmarchand Defender Technical Discussions 0 June 9th, 2004 12:42 PM
