300TDI fuel tuning guide - Defender Source
Old October 11th, 2010, 11:56 AM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
I came across this & thought I'd share
File Type: pdf Tuning_Land_Rover_Tdi_engines_Rev_2.pdf (397.9 KB, 151 views)
Old October 12th, 2010, 01:18 PM
andyrad
Andy Radlgruber
None.
Awesome write up. Maybe you should re-post it to the "official 300 tdi performance" thread for a clear reference there. I've had a few issues with the quality and clarity of the explanation of how it all works and this cleans it up quite a bit.
Some people are so heavenly minded that they are NO EARTHLY GOOD!
Old October 12th, 2010, 08:48 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
Will this work for the HS2.8 ? Similar injection pump??
Old October 13th, 2010, 12:59 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Heh, that mentions some of the little gotchas that I ran into last week. One that it doesn't seem to mention that adjusting the throttle pedal stop bolt will be required. Initially I kept making adjustments and saw some improvement but nothing on the top-end, then realized it wasn't adjusted, and that made a bit of a difference. However I suspect the biggest limiting factor now is the gearing, once I swap the drilled input gear over to the 1.4 case I suspect highway manners will improve dramatically, with the 1.6 box it loves driving at 80kph but any more and it feels like it's having a panic attack
Old October 13th, 2010, 01:02 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Yes, it is the same. Was also used by Dodge for a few years.
Old October 13th, 2010, 01:52 PM
will this work for the hs2.8 ? Similar injection pump??
x2!!
Old October 13th, 2010, 11:36 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Careful... You'll blow up your clutch!!!!
Keith
Big, Red and ... aaa Red..
300tdi, fuel, tdi
td5 fuel pump in a 300tdi Muscat Defender Technical Discussions 11 April 8th, 2010 10:35 AM
Looking for a 300TDI Fuel filter EdHsu Defender Technical Discussions 2 September 12th, 2004 01:11 PM
Fuel lines for NAS D90 with 300tdi? Chris Cox Defender Technical Discussions 3 December 5th, 2003 04:20 PM
