300Tdi Fuel Leak at Pump - Defender Source
Old August 3rd, 2016, 02:16 AM
RBBailey
RBBailey
1965 IIa
There is diesel coming out of the pump block itself. Maybe low along vertical seam, maybe higher, then running down. What/where should I look? What am I up against here?
Project:
1965 IIa SWB
Old August 3rd, 2016, 08:30 AM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Lift pump or inject pump? I've had more than one lift pump leak straight from the casing. They are cheap so buy another one if that's the case. If it's the injection pump I believe there is an internal o-ring that can cause a leak. There are threads about replacing it.
Old August 3rd, 2016, 09:08 AM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
If it is injection pump, I have complete seal kits for $19 + $6 shipping in USA.
They cover 200 and 300 TDI, but do not have the O-ring for the Disco 300TDI fuel trim shaft on the side of the pump that is unique to the Disc 300TDI.
If it's the lift pump and leaking out of the "leak hole" that you need a new lift pump.
RDavisinVA
Old August 3rd, 2016, 11:24 AM
RBBailey
RBBailey
1965 IIa
Sorry, it's the injection pump. And I believe this is a Disco version.
Project:
1965 IIa SWB
300tdi, fuel, tdi
300TDi vacuum-side fuel line leak mdcoa Defender Technical Discussions 4 July 27th, 2016 07:50 AM
Free (just pay shipping) - 300tdi vacuum pump (slight leak but repairable) hillstrubl For Sale - Parts 2 May 7th, 2015 08:49 AM
19J Fuel Pump Leak naw Defender Technical Discussions 2 July 5th, 2014 06:52 PM
TD5 Fuel Pump/ pump tomaco1 For Sale - Parts 7 September 20th, 2011 09:13 PM
feed 200tdi lift pump from Facet fuel pump ? kjva Defender Technical Discussions 1 September 7th, 2011 01:55 AM
