300tdi fuel filter Alternative (Shorter Body) - Defender Source
Old January 6th, 2011, 05:04 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Any ideas on a part # for a fuel filter for a 300tdi that is a little shorter then the stock one? Do they make one?
Legend in My Own Mind.
Old January 6th, 2011, 05:14 PM
Thanks to pendy, I went with a Racor, and never looked back. In the primary filter, I went with their shorter length.
Not sure what your issue is, but you should be able to make a riser for your existing filter pretty easily out of flat bar with 4 holes pretty easily. There should be room in the bonnet cavity to allow some vertical movement.
Old January 6th, 2011, 05:32 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Yeah, Racor is the way to go. There were several CAV filters fitted over the years, what model do you have?
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old January 6th, 2011, 05:37 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
any reason why I shouldn't be using the cooper/puralator one for an '84 diesel rabbit @ my local autozone?
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old January 6th, 2011, 07:23 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I just need about an inch of clearance for a custom shock mount setup.. Do they make a shorter filter for the stock filter assembly?
I like the racors but would rather save the $$ right now..
Old January 6th, 2011, 09:39 PM
My 2 cents I would try to relocate the filter.
Old January 6th, 2011, 10:49 PM
pendy's Avatar
pendy
jim pendleton
89'd90
The Wix filter for a 84 Volkswagen rabbit diesel works and is a shorter body.
legend in my own mind
Old January 7th, 2011, 07:55 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Part # anyone
Old January 7th, 2011, 08:10 AM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Proline PLF862 or Fram P1145A
~2008 GTI TSI
Old January 8th, 2011, 08:16 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
These are standard filters.
I found the shorter Wix one at Auro Zone... Thanks Guys
Old January 8th, 2011, 12:27 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
ahh sorry, I thought you were asking for the '84 rabbit part number. Thats what I get for skimming.
~2008 GTI TSI
Old January 9th, 2011, 10:55 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
No prob..
300tdi, body, fuel, tdi
Alternative to factory fuel filter... TNRoverGuy Defender Technical Discussions 4 March 31st, 2007 05:34 PM
Looking for a 300TDI Fuel filter EdHsu Defender Technical Discussions 2 September 12th, 2004 01:11 PM
Fuel lines for NAS D90 with 300tdi? Chris Cox Defender Technical Discussions 3 December 5th, 2003 04:20 PM
