300Tdi fan pulley mount - Defender Source
Old June 16th, 2014, 01:31 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
I stripped apart my 300Tdi engine this weekend and the fan was almost impossibly to get off. After using every trick in the book it was finally pulled off, but the end result was the threaded side with the 4 screw inserts pulled away from the bearing spindle.
I did some searching online and some Aussie guys use a Ford Falcon waterpump and press that bearing and threaded pulley mount off and use it. I also sourced a John Deere JD9257 bearing to use possibly with my old mount.
Has anyone replaced these without getting a new cover? Any state side water pump equivalents to the Ford Falcon?
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old June 16th, 2014, 02:44 PM
ini88's Avatar
ini88
Daniel Marcello
Some old Ford water pumps here might work. But I need to know the OD of the bearing or the ID to fit the mount.
http://www.ebay.com/itm/Engine-Water...447314&vxp=mtr
http://www.rockauto.com/catalog/x,ca...,parttype,2208
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old June 16th, 2014, 03:16 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I did that a few months ago, check on the forum I think there is a specific discussion on that topic. I got my bearing from Santiago, member of the forum, I think it came from Argentina. In the discussion I think I put pics of the bearing package, you can see the reference.
Cheers
------ Follow up post added June 16th, 2014 03:23 PM ------
The name of the thread is "300Tdi timing cover".
- Charles Eames
Old June 16th, 2014, 05:46 PM
ini88's Avatar
ini88
Daniel Marcello
Thanks Julien, I think I should be good with the bearing. But I still need that threaded part because that snapped from the 4 hole mount. Inside diameter is .62 I think.
I might be abel to pull it off and stick it back on, just not sure if it will hold well. I will experiment this weekend.
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old June 16th, 2014, 06:05 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Is your problem taking the spindle off the bearing shaft ?
Remenber when you're pressing everything back in place to folllow a certain sequence to make your life easier, and also take distance measurement before pulling out bearing and spindle.
Cheers
- Charles Eames
Old June 16th, 2014, 08:19 PM
You have to press the bearing out of the cover before trying to remove the threaded collar. Otherwise it will break as you have discovered. Measure the clearance between threaded boss and the timing cover so that you can get the spacing right when you press the replacement on. There is a jag idler pulley that uses a similar bearing. That's how I did mine. Belt still makes a racket.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old June 16th, 2014, 08:25 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I recently discovered that my mysterious chiming is coming from vacuum pump, it's next on the list.
- Charles Eames
Old July 6th, 2014, 12:09 AM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
How are you guys pressing the bearing out?
300tdi, fan, mount, pulley, tdi
idler pulley bearing 300TDI lrna04 Defender Technical Discussions 12 November 18th, 2013 04:19 PM
AC compressor pulley for fan hub? Axel Defender Technical Discussions 0 March 4th, 2013 08:58 PM
300tdi Crank Pulley JPRO576 For Sale - Parts 1 January 25th, 2013 12:53 AM
Tdi Air Conditoning Parts -3 Groove Pulley & Tensioner Mount Wolf Fabrication For Sale - Parts 9 August 16th, 2012 02:13 PM
300Tdi Fan shroud and fan Buckon37s For Sale - Parts 1 December 18th, 2009 10:46 AM
» Defender Registry
D90
bneri
Rosco
Cal
Add your Defender
