300Tdi / Fan cowl / high heat - Defender Source
Old May 19th, 2012, 12:57 PM
triple9music's Avatar
triple9music
Chad Davis
1984 Defender 90
I have a 300Tdi in an 84 D90 RHD and when I got it there was no fan cowl. Now that I've installed the fan cowl, there seems to be a huge space in between my fan and cowl.It never overheats, but the temp needle pegs right before the black on the highway.
Here's a pic. Is there a way moving my engine forward or I thought of using a 200Tdi fan cowl since it is longer or even having one fabricated.
I'm kinda stumped on this one.
Any help is unbelievably appreciated!! So addicted to this website!
Old May 19th, 2012, 01:51 PM
Naplm00
Matthew
There is supposed to be a f
Plastic piece that is offset. Goes from the Rad shroud to encompass the fan
Old May 19th, 2012, 02:40 PM
triple9music
Chad Davis
1984 Defender 90
That's what I thought but the guys at rovers north said that's the right fan cowl for a 300Tdi. I'm pretty confused about it. Matthew, do you know where I can order the plastic piece? It looks to me that a 200Tdi fan cowl would work but RN said it wouldn't and I'm assuming the intercooler on the 300tdi radiator wouldn't be covered.
Old May 19th, 2012, 10:23 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
On my 300 Tdi's the fan tucks right into the plastic cowling. It looks like your engine might be sitting back a little. Your Top Radiator hose looks longer than mine. Being an 84 the 300 was a transplant so they may have moved the engine back. What transmission do you have?
Land Rover 110
Old May 19th, 2012, 11:44 PM
triple9music
Chad Davis
1984 Defender 90
I've got an LT-77 transmission.
Old May 20th, 2012, 08:25 AM
Capt Milks's Avatar
Capt Milks
I might be wrong but the transmission you have will set the engine back depending upon the bell housing compared to the R380. Some others may be able to better give you information on this. If you measure where the leading edge of your motor mounts are, compared to the spring pirtch I can measure mine for you. But I would stand to figure that youe engine is set back further than the 300 with an R380.
Land Rover 110
Old May 20th, 2012, 11:07 AM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Looks like your motor is mounted further back. Post another pick that shows the bay.
If it is you have a couple options. Best one is to get a larger intercooler and mount the rad further back
Otherwise go custom cowl or consider an electric fan.
Regardless, you should not really need the fan on the freeway as there is plenty of air flow. Do you have a VDO guage?
Old May 20th, 2012, 05:55 PM
they used the old LT77 trans instead of the correct r380 to go behind the 300tdi. The r380 pushes the engine forward about 8 inches or so. You can probably fit a defender 200tdi or 2.5 TD fan cowl to your present setup if you are willing to cut it to fit around your hoses and generally get creative and make things work.
Old May 20th, 2012, 06:04 PM
triple9music
Chad Davis
1984 Defender 90
Ren, Steve and Mike,
you guys rock! that's for the most part what I was thinking but I wanted to hear it from you guys as I know you have more knowledge than me and WAY more knowledge than my mechanic who thought I had a 200Tdi.
I think I'll order the 200Tdi Fan cowl and get creative!
Thanks again guys!
Old May 20th, 2012, 06:15 PM
check with adrian in NJ he is pulling a 2.5td and might have the cowl FS
Thanks again guys!
Old May 20th, 2012, 06:27 PM
triple9music
Chad Davis
1984 Defender 90
gotcha, I think I know a guy in asheville who also has a cowl for a 2.5. I'll check with both.
------ Follow up post added May 20th, 2012 06:30 PM ------
any idea what Adrian from NJ uses for his member name? I know I've seen him on here. Does he have brad pitt on his avatar?
------ Follow up post added May 20th, 2012 06:36 PM ------
is it bossman429?
Old May 20th, 2012, 07:23 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Haha brad pitt.
Pm'ed replied
Old May 20th, 2012, 08:19 PM
triple9music
Chad Davis
1984 Defender 90
somebody has a pic of brad pitt from Fight Club I think as their avatar and it's so funny! Thought it was you at first! Thanks Adrian! hope your 200tdi works out!
Old June 6th, 2012, 03:16 AM
kylesrover's Avatar
kylesrover
Kyle
97 D90 ST #1018
Thanks again guys!
Hey Chad. Let me know If u replace your 300 fan cowl with the 200 one. I'm missing it on my 300.
300tdi, defender 90, fan, fan cowl, tdi
300Tdi cooler fan relay gone crazy JFD Defender Technical Discussions 8 April 7th, 2012 05:54 PM
300Tdi Fan shroud and fan Buckon37s For Sale - Parts 1 December 18th, 2009 10:46 AM
Viscus Unit, Fan Cowl, Alum Rim, Quarter Panel hank17 For Sale - Parts 1 October 26th, 2007 02:43 PM
