300Tdi Engine Smoking - Defender Source
Old August 3rd, 2016, 02:15 AM
RBBailey
RBBailey
1965 IIa
First test drive, no bonnet, smoke coming out of engine block. Can't tell where exactly, but something is close to catching on fire. After stopping, the smoke clears fairly soon, and no sign of oil or anything burning.
Ideas?
Project:
1965 IIa SWB
Old August 3rd, 2016, 03:47 AM
Was the turbo painted? I had that happen and almost crapped myself.
Old August 3rd, 2016, 03:49 AM
RBBailey
RBBailey
1965 IIa
No. And although it was coming from center upper part of engine, maybe from that side, I did not see that it was coming from the turbo.
Project:
1965 IIa SWB
Old August 3rd, 2016, 06:48 AM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
Leaky oil feed or drain on turbo dripping onto something hot?
Old August 3rd, 2016, 06:59 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
What is the color of the smoke, does it have any particular smell? Sounds like something isn't hooked up or paint burn off.
Land Rover 110
Old August 3rd, 2016, 08:33 AM
RiftRover's Avatar
RiftRover
Mike Barnett
110
I had the happen recently and it was the gasket between the turbo and the downpipe. Look for soot on the side of the block or elsewhere and it will give a clue as to where the source is.
Old August 3rd, 2016, 11:26 AM
RBBailey
RBBailey
1965 IIa
It is greyish smoke.
I'll be running it again today. I'm going to hook up the PSI, Temp, and EGT before running it to warm again....
Project:
1965 IIa SWB
Old August 3rd, 2016, 12:12 PM
My guess is a bad ring that is pushing massive pressure up thru the valve train and out the valve cover or whatever the path of least resistance happens to be. AKA the "Pedro effect" in honor of his 19J that had this.
Old August 3rd, 2016, 12:21 PM
RBBailey
RBBailey
1965 IIa
So my new engine needs a new engine.
Project:
1965 IIa SWB
Old August 3rd, 2016, 12:42 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
dude, don't fall apart. have a beer and relax. buy a few cans of brake clean and get things cleaned up first. slowly check all hoses, lines for connection security. check fluid levels, oil filter and check the valve cover gasket.
Is there any history on this engine? Has it been rebuilt recently?
Old August 3rd, 2016, 01:04 PM
I second relaxation.
There's no way that anyone here can diagnose this online for you, but we can spur you on.
You can do it!
Old August 3rd, 2016, 01:50 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
My 300Tdi was smoky, smelly, sooty and all for a week or two after I first installed it.
It was suckin air here, leakin diesel there...
I just thought they were like that.
It had been sitting for months.
Now it runs great and I cant hardly make it smoke even when I want to...
Just get your gauges hooked up, run it a bit and report back.
Rent my
Old August 3rd, 2016, 01:53 PM
KGH's Avatar
KGH
Real Name
#1-'13 110SW,#2-'87 127,#3-'12 LR4
Just posted the Rebuild manual.
Have a beer, get some wrenches and fix this freakin' lump!
It's a Rover. They do this.
Tame it.
KGH - “Stinky LR diesel” Defender Snob
Old August 3rd, 2016, 02:34 PM
RBBailey
RBBailey
1965 IIa
Thanks, I have the manuals. Was hoping to not have to use them for a while since I thought I had paid to have the engine dialed in.
Project:
1965 IIa SWB
300tdi, engine, tdi
300TDI smoking on start up graham Defender Technical Discussions 7 February 2nd, 2017 04:50 PM
Help! Smoking 300TDI leonus1 Defender Technical Discussions 29 September 15th, 2013 08:58 AM
Defender 300TDI smoking graham Defender Technical Discussions 5 May 24th, 2013 10:02 AM
smoking deal on a Howling Moon 1.4 RTT Uncle Douglas The Flea Market 0 July 15th, 2011 10:19 AM
300TDI new injectors - smoking like mad jaherring Defender Technical Discussions 4 May 2nd, 2011 11:58 AM
